zz-x
Old Sep 20, 2002 | 06:26 AM
devilfish's Avatar
devilfish
Default zz-x
Whats the deal on this cam from tpis? Is it better choise then the zz9 with a miniram setup?
Old Sep 20, 2002 | 09:42 AM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Default Re: zz-x (devilfish)
not for street driving....Ive heard the valves have to be adjusted every few thousand miles.
Old Sep 20, 2002 | 10:36 AM
-=Jeff=-'s Avatar
-=Jeff=-
I have the ZZ9 with my Miniram. I am happy with the performance but I think the ZZ-409 would be better. If I didn't get the great deal on my ZZ9 when I got it, I would have done the ZZ-409
Old Sep 20, 2002 | 01:42 PM
vader86's Avatar
vader86
I too think the ZZ409 would be better for street use, but the ZZ9X should make a bit more power because of the longer duration on the intake side
Old Sep 20, 2002 | 02:13 PM
devilfish's Avatar
devilfish
Default Re: zz-x (vader86)
Why would the zz409 be better? More low en power?
Old Sep 20, 2002 | 02:15 PM
vader86's Avatar
vader86
because you would make enough torque down low, and you would still be able to have a good idle as compared to the ZZ-X
Old Sep 20, 2002 | 02:22 PM
thetorch's Avatar
thetorch
What are the specs on the zz-x cam?
Old Sep 20, 2002 | 05:23 PM
gtsyellow's Avatar
gtsyellow
Default Re: zz-x (thetorch)
the zzx cam is almost too big for a hyd. lifter the zz409 cam is almost perfect for a street / strip MR engine, the 409 isn't really all too far off the grind i have & i'm just thrilled peak power is rougly 6200-6400rpm by seat of the pants feeling & i shift at 6500 with a rev limiter set at 6700. the one thing i do like about the MR is it killls some of the low rpm torque, on a 6spd car it's definatly nice. with the old TPI the engine woke up so fast it was all but impossible to get traction on street meat. as it sits with the MR i can drive 10mph, punch it & have traction till roughly 4500rpm, once i get in the power band it just breaks loose. with a little skill i can keep it planted but i definatly know i'll be running faster ET's with better rubber !!
Old Sep 20, 2002 | 06:49 PM
devilfish's Avatar
devilfish
Default Re: zz-x (gtsyellow)
what combo is good with the zz409? afr 190s? headers? miniram or superram?
Regards
[Modified by devilfish, 11:52 PM 9/20/2002]
Old Sep 20, 2002 | 07:03 PM
vader86's Avatar
vader86
AFR 190s, Miniram, 1 3/4" headers
Old Sep 20, 2002 | 07:13 PM
devilfish's Avatar
devilfish
400hp?
Old Sep 20, 2002 | 07:16 PM
vader86's Avatar
vader86
400hp?
crank, probably with good tuning
Old Sep 20, 2002 | 10:06 PM
gtsyellow's Avatar
gtsyellow
more, with afr 190's a MR 11:1 and 409 you'd be closer to 440hp
To zz-x
