1994 Corvette, Inside Air Temperature Sensor
I get the 06 code from heater control head showing Inside Air Temperature Sensor Short. Where is it located and has anyone had this issue. This is my first C4. The problem is the heat does not get hot and I ran across the way to find the codes from the head unit.
Any suggestions.
Any suggestions.
My 94 has a sensor under the bumper on the pass side. Not sure if it is the one.
The "inside" is likely accessible by removing the RH hush panel and knee bolster for diagnostics. It mentions that replacement can be done by removing those so ...
if you don't have the FSM for a '94 car you're just poking around.
