15" wheels on rear ?
Old Dec 30, 2016 | 11:21 PM
vetteman9368's Avatar
vetteman9368
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
Default 15" wheels on rear ?
I know I can be done. I remember something about having to grind on the caliper, but can't picture it in my head. Also, drag racing guys, how big of a tire have you fit on there?
Old Dec 31, 2016 | 09:09 AM
89L98TPI's Avatar
89L98TPI
I'm running 15s on rear. I have 12 inch rotors and we grinded the fins down on caliper. I'm running a 275/60/15 and 28x10.5
Old Jan 1, 2017 | 08:16 AM
C409's Avatar
C409
..... No grinding calipers/no clearance issues ... 87 Vette with 15x8" Weld Pro Stars running a 275/50/15 Mickey Thompson Drag Radial or 15x10's with 26 x 10.00 ET Drag Slicks ... I have had 28 x 10.50's on it but with the taller tires you have to set the bump stops to keep the fenders off the tires . I found I was launching on the stops and went back to the shorter tires to let the suspension do its thing ... the pic below shows a wheels-up launch on the 15x8 Pro Stars that are for sale on this forum with the Drag Radials mounted .....
Old Jan 2, 2017 | 05:46 PM
vetteman9368
St. Jude Donor '08
wondering how much work I'm going to have to do to get 315 drag radial under it. I'm about to start working on it for drag week (2018).
Old Jan 2, 2017 | 08:40 PM
C409's Avatar
C409
..... What makes you think you need that much tire ? Huge shot of Nitrous ? .....
Old Jan 2, 2017 | 09:04 PM
vetteman9368
St. Jude Donor '08
Looking to go 8's at drag week. Race brakes will come, but I gotta get the car running/driving first.
Old Jan 4, 2017 | 01:56 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
15x10 7.5 backspace and a 5/16 spacer. I ran 11.5x28x15 ET Slick. Fit fine. If you have the larger brakes you do need to grind the fins on the calipers. I used the same tire rim with both the IRS and the solid rear. I always wanted to try a 9" radial stocker tire on my car but never got to do it. Hope this helps.
Old Jan 4, 2017 | 03:47 PM
vetteman9368
St. Jude Donor '08
Thanks John, glad to see you around!
Old Jan 4, 2017 | 04:34 PM
mackeyred96
Thanks, I've havn't posted much in the last few years but I do lurk! Saw this post and thought I could give you all the right info! I sold my car 4 years ago, that would have been a great car for you.
Old Jan 4, 2017 | 05:14 PM
vetteman9368
St. Jude Donor '08
that it would. My car has been stored for the last 4 years (getting married and starting a family will do that). It's a basket case. I'm working on some CAD drawings for trying to bullet proof the D44 (I have some ideas that I've learned from our C3 stocker). Going to do a turbocharged LS motor and turbo 400 (with trans crossmember). It's going to be a street car, but I want to run drag week with it at some point. I'd put a straight axle in it, but that will put me in a class that I'd have to run mid 7's to compete in. We've got one serious race car, this is for fun
To 15" wheels on rear ?
