Hand Porting Al Heads?
Old Sep 20, 2002 | 05:23 PM
KYVette90's Avatar
KYVette90
Default Hand Porting Al Heads?
How much HP could be gained by hand porting the aluminum heads from a 90 L98? Has anybody done this with a noticed improvement? :cheers:
Old Sep 20, 2002 | 05:24 PM
GusBustamanteJr's Avatar
GusBustamanteJr
Default Re: Hand Porting Al Heads? (KYVette90)
I would be careful, I read in several places that if you open certain areas too large, the port velocity drops and you do more harm than good.
Old Sep 20, 2002 | 05:28 PM
gtsyellow's Avatar
gtsyellow
check this thread http://forums.corvetteforum.com/zerothread?id=379838
Old Sep 20, 2002 | 05:33 PM
sinistervette's Avatar
sinistervette
It depends on your knowledge of airflow, port design, and velosity. I hand port all of the cylinder heads, intake manifolds, and carburator that I use for myself as well as the ones I sell/install on other peoples engines. Hand porting is not inferior to cnc porting, as long as the person doing it has the proper knowledge and tools to do the job correctly. If the person programing the cnc does not understand the proper way to port the runner in which he is working on, it will be just as junk as one done by hand if the person doing it by hand doesn't know what he's doing either! CNC, is faster, and therefore less expensive, but it does not make it better. If you understand what you are doing, and have all the correct tools/instruments for measuring and doing your work, hand porting is just as good as cnc. As for improvements, it all depends on how far you are willing or capable of going. Yes, there is definiately room for improvements. :cheers:
[Modified by sinistervette, 9:34 PM 9/20/2002]
Old Sep 20, 2002 | 05:39 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The stock #113 heads are rated to flow to about 350hp and, pocket ported, to over 400hp. It should be worth about 25hp gain along with other appropriate air and fuel flow mods to a 350cid TPI engine.
As mentioned, if you've not ported heads, do your homework and get the proper tools. Summit has a good video from Standard Abrasives to get you started. If you don't have access to a die grinder I can give you a P/N to a Sears electrical unit that was used for a mag article on head porting.
[Modified by 65Z01, 3:43 PM 9/20/2002]
Old Sep 20, 2002 | 06:16 PM
KYVette90's Avatar
KYVette90
Default Re: Hand Porting Al Heads? (65Z01)
I have access to a die grinder, thanks anyway. Is there any gain from polishing the ports and gasket matching to the intake?
Old Sep 20, 2002 | 10:18 PM
No Go's Avatar
No Go
I leave head porting to the pros...reason why they get paid for their knowledge especially on today's rather refined heads.
To Hand Porting Al Heads?
