Should I get a torque converter and shift kit?
Also does anyone know what I can do to the L98 to up the horsepower? I am curious as to what makes the LS1s and LT1s so much better than the L98s if they are all fuel injected 5.7 liters. Can I make mine run with the newer vettes?
Thanks in advance!
To run with an LT1, a 2000-2400 stall TC (Vigilante makes the best, but theyre expensive) and 3.07 gears would be a big help. Then do the "free" mods: Throttle body bypass (remove the 2 coolant hoses from the TB and mate them together), K&N Filter and open lid, 160 thermo and a fan switch (L98s like to run cooler than the factory designed them), remove the screens from the MAF sensor.
Then youll need headers/exhaust. With that, an LT1 might only barely beat you but as always, it depends on the driver.
For enough to beat LS1s, youll need a Miniram or Superram.
Several things make the LT-1 and LS-1 more powerful, not the least of which is the shorter runner intake. Of coures more efficient heads and better cam don't hurt.
I recently had Grant Transmission in CT install a 2,000rpm TC (stock is 1,500rpm) and TransGo shift kit and dropped my ET by .3 sec. I also get a nice loud chirp on the 1-2 shift at moderate throttle, sometimes even at the strip.
I'm sending you a recipe that will get you well into the 12s; if you want to start with simple bolt-ons check out my site and that of Vic'89.
