**911** Balancer reinstall HELP!
Old Sep 20, 2002 | 08:19 PM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
Default **911** Balancer reinstall HELP!
I made a mistake and cranked the engine after I had marked the balancer.
How do I figure out which way it goes? There is an arrow on the balancer but what is the indicator on the hub to match that to? I do see a nub on one side and then on another side of the hub is kinda an arrow is that it? Service manual is no help.
[Modified by Rex Ruby, 7:29 PM 9/20/2002]
Old Sep 20, 2002 | 08:45 PM
kabnvtt's Avatar
kabnvtt
Default Re: **911** Balancer reinstall HELP! (Rex Ruby)
Hellow, if you are trying to put the balancer back on to the crank there is a key crank that the balancer slides over onlly goes on one way. If you are trying to time the car there should be degree marks on the balancer. Need a little more info on what you might be having problems with. There is a slot on the balancer that is 0. At least on my 87 not sure about yours. Good luck.
[Modified by kabnvtt, 12:48 AM 9/21/2002]
Old Sep 20, 2002 | 09:14 PM
Rex Ruby's Avatar
Rex Ruby
Default Re: **911** Balancer reinstall HELP! (kabnvtt)
Actually there is NO KEY on the crank HUB.
I checked the vert and the arrow on the balancer lined up with the arrow on the hub. Hope it's correct :cheers:
[Modified by Rex Ruby, 8:41 PM 9/20/2002]
Old Sep 21, 2002 | 01:19 AM
Rex Ruby's Avatar
Rex Ruby
Got done and ran her all seems to be OK :cheers:
Old Sep 21, 2002 | 02:26 AM
5abivt's Avatar
5abivt
all i saw was a line between 2 spokes on the hub. I lined this up with a mark on the balancer and it worked perfect.
Old Sep 21, 2002 | 03:26 AM
jkingsbury's Avatar
jkingsbury
Default Re: **911** Balancer reinstall HELP! (5abivt)
I've been trying to figure this out for a while now, since I too wasn't sure I had correctly marked the balancer vs the hub when I removed the balancer. The conclusion I came to was to align the arrow on the balancer with the arrow which is on the hub between two of the legs. I haven't put it all the way back together yet. I'm glad you came to the same conclusion and yours runs fine. :cheers:
To **911** Balancer reinstall HELP!
