manifold red hot
options? dangers?
I'd also check timing as danlb suggested...although that would typically affect both sides.
Welcome to the forum.
hot exhaust doesn't necessarily mean vacuum leak, it means lean. generally, lean means vacuum leak but not always. Usually, the motor runs in closed loop mode and can compensate automatically for a lean condition by adding more fuel. However, while it is warming up it is in open loop fueling mode and has no way of knowing it is lean.
The other option besides a vacuum leak is that the IACs (Idle air controllers) are wide open, which is likely if any sort of work has been done on the Throttle bodies recently. (sounds like it has). The IACs can be automatically reset by driving to 45MPH for a few seconds (its actually that simple) This problem would also be temporarily compensated for by closed loop mode if it had time to warm up enough to get there, but I dont recommend running it long enough for it to go closed loop if the exhaust is that hot.
If its just one primary tube it might be an incorrectly adjusted exhaust valve, I think. This would result in a ruined valve if the motor was used without correcting the issue.
Good luck and welcome to the forum
This was retarded timing related. So to say "extremely rich" is very subjective.
Maybe another can chime in...
