Worried about whining noise from trans
When your foot is OFF the clutch the motor and Trans are spinning together and the pilot bearing is doing nothing since the motor and input shaft are spinning together at the same rpm...
When you step on the clutch pedal DEPRESS the pedal the pressure plate is appling pressure to the TOB and that is normally when it whines. There is no pressure on the TOB when your foot is not on the pedal.
