SMOG TEST ANY TIPS TO HELP PASS (CA)
Old Sep 20, 2002 | 11:18 PM
blkc6z51's Avatar
blkc6z51
Default SMOG TEST ANY TIPS TO HELP PASS (CA)
Need to get a smog test soon, do you have any tips that
will help me pass. 90 6spd. Thanks for any tips.
Richard :chevy :cheers:
Old Sep 20, 2002 | 11:22 PM
dbwade36's Avatar
dbwade36
Default Re: SMOG TEST ANY TIPS TO HELP PASS (blk90)
Any Mods? You didn't really say much about your current setup. Have you failed SMOG before? Why do you feel you need advice on how to pass this time?
Old Sep 20, 2002 | 11:30 PM
blkc6z51's Avatar
blkc6z51
Default Re: SMOG TEST ANY TIPS TO HELP PASS (dbwade36)
No mods, all stock car has 70,000 mi. No never failed before, just want to make sure I don't. :cheers:
Richard
Old Sep 20, 2002 | 11:32 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Old Sep 20, 2002 | 11:34 PM
StarShipCmdr's Avatar
StarShipCmdr
If you think you'll have problems - Dry Gas - about 4 to 6 cans. It may be a rare commodity in the land of perpetual summer, but anything with methanol or alcohol in it might work as well. Have it hot - deep hot - a 20 mile trip prior to testing should do it. Good Luck.
Old Sep 20, 2002 | 11:38 PM
blkc6z51's Avatar
blkc6z51
Default Re: SMOG TEST ANY TIPS TO HELP PASS (Mr Mojo)
Mr Mojo
Thanks for the Tip, now if I could just spend it. :D
Old Sep 20, 2002 | 11:45 PM
don hall's Avatar
don hall
If your car is running smoothly, you should not have a problem at 70K miles. If you are concerned, there are smog stations that advertise: "No charge if you don't pass". You pay about $10 extra, if you pass. Beware, as these stations also repair smog related items to get your vette through the process. It would be advised to validate the shop by asking anyone who has used their services for a recommendation.
Old Sep 21, 2002 | 12:20 AM
hngacurv's Avatar
hngacurv
Default Re: SMOG TEST ANY TIPS TO HELP PASS (Oldman)
I don't think you will have any problems, but if you think you need help I have heard of some people having good luck with a product called guaranteed to pass.
Old Sep 21, 2002 | 01:46 AM
keekster's Avatar
keekster
Get it nice and hot. Heat up those CATS. :)
Old Sep 21, 2002 | 02:31 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Put the engine in field test mode and see if the O2 sensor is OK.
Some dry gas helps.
Make sure it is up to operating temp when you go in for the test.
Old Sep 21, 2002 | 04:18 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: SMOG TEST ANY TIPS TO HELP PASS (65Z01)
Worn out catalytic converters will give you high hydrocarbon levels (HC).
Retard the timing two degrees.. that will help burn the fuel better.
Put in a clean air filter, and 87 octane gas.
This will keep your Hydrocarbon emmisions low. I did neither of these on my Ford, and ended up failing.
Old Sep 21, 2002 | 10:35 AM
VetteRacer282's Avatar
VetteRacer282
My advice.. take it to a shop that does free resmogs if you fail the first time... Just in case...
As a note, our 88 with 160-170k miles on it passed smog no problem. That wasnt even warmed up more then the ~10 mile drive to the smog shop.
Goodluck... and if all else fails... find a crooked smogger ;)
Matt
Old Sep 21, 2002 | 11:40 AM
Oly's Avatar
Oly
I just passed the smog test with my '92 about a month ago. She has 101,000 miles on her; only thing I have replaced is the Oxygen sensors. You shouldn't have any problems if yours is running well.
Good luck.
To SMOG TEST ANY TIPS TO HELP PASS (CA)
