EMERGENCY, FAILED EMISSIONS AND NEED ADVICE
Old Sep 21, 2002 | 02:41 AM
allchevy95's Avatar
allchevy95
Cruising
Default EMERGENCY, FAILED EMISSIONS AND NEED ADVICE
I did my emissions testing the other day and I failed. The reason I failed is because the previous owner of my car for some reason or another gutted the passenger side cat. I need some cost effective ideas for passing. I am on a tight budget. I am good with welding so if there is another cat I could pull from a junk yard and weld up I would more then appreciate the info. thanks.
Old Sep 21, 2002 | 02:49 AM
Raysur's Avatar
Raysur
Default Re: EMERGENCY, FAILED EMISSIONS AND NEED ADVICE (allchevy95)
How badly did it fail?
The cheapest thing you can do is a bribe.
If you don't want to go that route run some racing fuel in your tank.
Or you can buy a bullet cat for $80. Summit Racing has some and so does Car Sound. They are very small cats.
Some here on the forum have passed smog tests with no cats. I want to know the trick. :D
Old Sep 21, 2002 | 11:09 AM
silver & red CE's Avatar
silver & red CE
You'll definately need a cat to pass IM240 (the roller test). Why don't you give Vette2Vette a call? They have used cats from salvaged Vettes and they're only about 30 mins from Naperville.
815 287 9878
If the test is just an idle speed sniffer, you can pass without cats. If the test is on the rollers (IM240) you'll never pass without cats.
Eric
Old Sep 21, 2002 | 11:16 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: EMERGENCY, FAILED EMISSIONS AND NEED ADVICE (Raysur)
:nono: And as soon as you get caught it won't be the cheapest thing you can do. I hate emissions testing and I think it's a joke, but if we had it I would make my car pass it. Bribery will get you in trouble eventually.
Old Sep 21, 2002 | 11:28 AM
StealDads67's Avatar
StealDads67
Default Re: EMERGENCY, FAILED EMISSIONS AND NEED ADVICE (Nathan Plemons)
Well.... wat failed? It might not be the cat.... What was over the limit.... Hydrocarbons?..... Nox???.... If you can tell me what was over, i could help you out a little more.... There are a lot of little tricks to get a car through....
Old Sep 21, 2002 | 12:03 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Default Re: EMERGENCY, FAILED EMISSIONS AND NEED ADVICE (StealDads67)
what tricks to get Nox down???? :D
Old Sep 21, 2002 | 03:20 PM
StealDads67
Default Re: EMERGENCY, FAILED EMISSIONS AND NEED ADVICE (Marcho Polo)
The way to figure if the Cat is causeing the problems You have to see the chart, If the HC and the CO are peaking at the same time, it the cat, they should be peakin at opposite times....
NoX... Is produced from the cylinder wall temps being to high... You need to find a way to cool down the car...
Couple tricks are.... to boost fuel pressure, Take the vacuum hose off the Fuel pressure regulator... But doing this will bring up the HC and CO levels.... make sure you have enough head room to do this.... This should help... If that doesnt work try Water squirt into the intake, or put a block of dry Ice on the Air Filter
Hope this helps, it should def get you through, Nox are easy to get down
To EMERGENCY, FAILED EMISSIONS AND NEED ADVICE
