Digital dash
Old Jan 24, 2017 | 07:51 PM
Als86Corvette's Avatar
Als86Corvette
Default Digital dash
Is there a way to keep my digital dash on my 86 Corvette bright at night time
Old Jan 25, 2017 | 06:05 AM
hcbph's Avatar
hcbph
Never tried it but what about putting a piece of black tape over the light sensor on the instrument cluster and see what happens?
Old Jan 25, 2017 | 02:24 PM
xrav22's Avatar
xrav22
Make sure yourDimmer is turned up .
Old Jan 25, 2017 | 02:40 PM
Hot Rod Roy's Avatar
Hot Rod Roy
That's backwards. When the sensor sees darkness, it dims the dash lights. You need the dash lights brighter in the daytime so you can see them better.
You could shine a flashlight into the sensor at night! That should make them brighter. That might be a good test!
Als86, are you sure all four light bulbs in the dash are good?
Old Jan 25, 2017 | 04:19 PM
slow-vette's Avatar
slow-vette
Switch over to LED back light. I did mine and they are much brighter at night but not too bright and they don't really dim. I used the kit offered at www.batee.com and have been very happy with it. Another nice side benefit is that it stops all heat related damage to the cluster from the standard bulbs.
Old Jan 25, 2017 | 06:28 PM
Als86Corvette
Default digital dash
I have tried the headlight switch to brighten it with no results only the information center lights brightened and dimmed, never thought about LED I might give that a try and look into it , what number is the bulb?
Old Jan 25, 2017 | 10:33 PM
xrav22's Avatar
xrav22
I put this kit into mine and it is much brighter. Be carefull with the small ones they tend to be stuck pretty good and they don't have new holders. I twisted them out without a break.
http://www.ebay.com/itm/112137765664...X%3AIT:cheers:
To Digital dash
