Short in fan switch causing high idle?
Old Sep 21, 2002 | 09:55 PM
poppy's Avatar
poppy
Cruise-In III Veteran
Default Short in fan switch causing high idle?
This is what I've found out but don't know why or how. First I have a 180 deg. switch and have noticed that the temps will rise over 200 the same time my idle speed wants to stay above 1000-1100 rpms. Twice I've gotten under the hood to notice the fan blowing at half speed. When I play with the switch plug-in the fan jumps to high speed and the idle starts to drop to normal along with the temps. :confused: Why the high idle when the fan shorts out?
Old Sep 21, 2002 | 11:37 PM
LarryK 87's Avatar
LarryK 87
Default Re: Short in fan switch causing high idle? (poppy)
possibly a bad ground(s) G-101 & G-104 and G-101 to G104, also check the Fan grounds at the front frame area.
