cam comparision
Old Jan 26, 2017 | 12:24 AM
Eduardo L98 1991's Avatar
Eduardo L98 1991
Default cam comparision
L98 1991
I recently installed a competition cam 8-302-8 with 1.6 rr, the reason of why I choose 8302-8 over 8-304-8 was because I already have the 1.6rr and I red that the max lift with oem heads is .525
Competition Cams
Model Number .05" Duration 1.5:1 Lift 1.6:1 Lift Lobe Sep.
08-302-8 210/220 .480/.480 .512/.512 112deg
08-304-8 210/220 .500/.510 .533/.544 114deg
10111773 OEM 202/207 .413/.428 .441/.457 114.5
At numbers is almost the same but I supose the difference will be the lobe sep
big diference over the oem cam
Sounds stock, idles great at 750 rpm, I supose that 8-302-8 with 1.6rr is a better option for me than 8-304-8 with 1.5rr at this moment
Im joining parts for a few years but I cant afford yet the heads, then Im using the parts that I already have
Probably this cam combo will be mild for new heads
mods
accel big mouth base heavily ported to 190cc (little siamese)
slp siamese runners ported and siamese in both sides
hooker headers
1.6 rr
comp cam 8-302-8
lt4 springs
custom prom (harris)
2200 stall converter
3.54 rear end
Old Jan 27, 2017 | 07:16 AM
ghoastrider1's Avatar
ghoastrider1
welcome back. haven't seen you post in a while.
Old Jan 27, 2017 | 05:56 PM
cv67's Avatar
cv67
St. Jude Donor '05
theres so little difference between those cams not worth sweating over
Same with 1.5 over 1.6 rockers
Old Jan 27, 2017 | 08:24 PM
Eduardo L98 1991
08-302-8 210/220 .512/.512 112deg 1.6rr
08-304-8 210/220 .500/.510 114deg 1.5rr
same duration, more lift, the diference here is 2 degree of lobe separation 2.5 degree less than oem
with oem chip idle quality is poor, with custom chip idle quality is like oem, I supose map is sensible to this changes
To cam comparision
