Adjustable Fuel Pressure Regulator Setting Recomendation
Old Jan 27, 2017 | 12:17 PM
mixalive's Avatar
mixalive
Default Adjustable Fuel Pressure Regulator Setting Recomendation
I have a stock 92 LT1 with Walbro fuel pump, factory injectors, minus the pulsator. I may have issue with my factory fuel pump regulator and am considering installing an adjustable unit.
I am requesting the optimal pressure setting for the adjustable fuel pressure regulator.
Old Jan 27, 2017 | 12:59 PM
Eduardo L98 1991's Avatar
Eduardo L98 1991
42-45 baseline, then adjust richer or leaner
Old Jan 27, 2017 | 02:18 PM
aklim's Avatar
aklim
Not sure if you can really adjust it too much since if you jack up the pressure a little, I would think the ECM would sense the richness and compensate. Kinda why I set mine at stock pressure and still do especially since the ECM has been set up for my new system. It might go richer for a while and you may even get away with it in WOT runs but for normal driving, it probably will adjust the pulse width back.
Old Jan 27, 2017 | 02:44 PM
mixalive's Avatar
mixalive
Thanks Guys..
Old Jan 28, 2017 | 01:19 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Well if you change fuel pressure you need to change the injector constants too. That means a new tune and in a '92 that would take a new ECM chip.
Best just to set it to stock which is 41psi with the engine off. Now if you have an adjustable regulator and the pressure is to high when you turn the key (but not to start) then you of course need to bleed off some press before readjusting. Finally I would start the motor then shut off to measure the fuel pressure one last time engine off to verify you got it right.
Hope this helps.
Old May 11, 2018 | 10:19 AM
mixalive's Avatar
mixalive
Thanks. I reinstalled with a factory non adjustable unit.
Hope this helps.
To Adjustable Fuel Pressure Regulator Setting Recomendation
