'84 Heater Valve
Old Feb 2, 2017 | 04:29 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Default '84 Heater Valve
I've been struggling with a leaky heater control valve in my '84 for a while, and finally found a good answer! I have seen a few suggestions on how to repair this valve, but I think I've found a better way. The heater valve for an '85 Buick Century 3.0 L V6 fits even better than the stock '84 Corvette valve! Here's a shot of the '84 "octopus" valve:
And here's a shot of my new Buick valve:
It fits directly to the tubes to my heater core, and the tubes are even the correct spacing and the correct diameter! The water flow is correct (bottom to top) to purge bubbles from the core, and bypass of water from the rear of the intake manifold to the water pump is correct when the valve is off! 4 Seasons p/n 74800. And RA has them on sale for less than $5! Such a deal!
Old Feb 2, 2017 | 04:36 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That is a sweet find...and a damn nice fit!
I have to wonder though...why not just eliminate this fussy part? The blendair door does the job of managing heat just fine.
Old Feb 2, 2017 | 08:44 PM
WVZR-1's Avatar
WVZR-1
The 74800 valve has been an accepted/recommended valve for many years. The number looked familiar -
A push towards the top so others might take notice - I don't need and don't buy from RA
Old Feb 2, 2017 | 10:15 PM
Hot Rod Roy
That's news to me! I've tried all the SEARCH functions I could think of, and couldn't find this info, but then again, that SEARCH system just gets me frustrated! You're right again, as usual!
Old Feb 3, 2017 | 07:28 AM
ex-x-fire's Avatar
ex-x-fire
Good job Roy!
Old Feb 7, 2017 | 04:11 PM
Hot Rod Roy
That might be true in Utah, but in SoCal it gets pretty warm, so I'd rather not have any more heat in my max A/C air, or in my cool vent air than necessary. My original only lasted 33 years, so I don't think it's too fussy! Now I'm good for another 33!
I've seen it recommended to cannibalize and replace the core of the stock heater valves, but not as a complete replacement valve. After figuring out how the valve worked, I was surprised that it could be used complete, as is, and it fits so good, and does everything right!
I thought for sure someone would let me know this would cost me points in my NCRS judging!
Old Nov 30, 2017 | 01:50 PM
71TTop's Avatar
71TTop
RA is out of stock on this valve right now.
Old Dec 5, 2017 | 07:21 AM
Gibbles's Avatar
Gibbles
I picked up a brand new heater valve off of amazon for roughly $120, it was an exact match to the original in my 84 except it was painted black, vs the original being silver.
Old Dec 5, 2017 | 07:24 AM
Gibbles's Avatar
Gibbles
Here she is:
​​​​​​​ACDelco 15-5344 GM Original Equipment Heater Water Flow Control Valve https://www.amazon.com/dp/B000C9DDMG/ref=cm_sw_r_other_apa_0-OjAb6SC040N
Old Dec 5, 2017 | 08:51 AM
71TTop's Avatar
71TTop
Default '84 no heat
Originally Posted by Gibbles
Here she is:
​​​​​​​ACDelco 15-5344 GM Original Equipment Heater Water Flow Control Valve https://www.amazon.com/dp/B000C9DDMG..._0-OjAb6SC040N
Mid American Corvette has them at $122.
Old Jan 11, 2021 | 03:17 PM
Elijah Collins's Avatar
Elijah Collins
3rd Gear
How does this work on the 84? Since rh3 original one has 3 stems while this one has 4?
Old Jan 11, 2021 | 06:59 PM
Krusty84's Avatar
Krusty84
My '84 isn't stock (ls swapped) but uses a simple one way valve on the inlet side of the heater core. It doesn't have a bypass but my surge tank with pressure cap is on the firewall and is in the highest spot of the coolant system. Haven't any issues with it. I think these type of valves run about $15-$20.
To '84 Heater Valve
