How to ID Good GM Optispark
Old Feb 6, 2017 | 11:24 AM
LTxDave's Avatar
LTxDave
Default How to ID Good GM Optispark
How can I tell if the optispark I purchased years ago is a "good" one with the Mitsubishi sensor vs the not so good later replacements?
Old Feb 6, 2017 | 11:35 AM
WVZR-1's Avatar
WVZR-1
I always understood you had to do a visual on the sensor BUT it might be interesting maybe to check the part# on the distributor and in the same vicinity there's likely a "date code" of sorts that could answer the question without the "open to peek"!!
Post the info off of yours and maybe a snapshot?
Old Feb 6, 2017 | 11:53 AM
Silver96ce's Avatar
Silver96ce
Open it up - it won't cause any problems to do so. You can check the rotor screws and blue locktite them at the same time.
There should small Mitsubishi diamond logo on it and there may be a dot of light green paint also. The paint dot was on the ones I bought used.
Here's a link with photos -
https://www.impalasuperstore.com/nai...TOPIC_ID=47010
It's the 15th photo and about 1/3 down the page showing the logo and paint dot.
Old Feb 6, 2017 | 12:18 PM
40flier's Avatar
40flier
You tube test hook it up to car, wire to plug, spin with drill, look for spark
Old Feb 7, 2017 | 07:55 AM
LTxDave's Avatar
LTxDave
I looked to last night and could not see any date codes when installed on the engine. I was more interested in getting tunercat to talk to my 95 than ID the opti on the spare engine.
Thanks for the info guys! Now I will know when I year down the engine of ours worth keeping.
Old Feb 7, 2017 | 08:12 AM
LT1_383's Avatar
LT1_383
@LTxDave, a new option to TunerCat is EEHack on the fbodytech.com website. Take a look at it. It's free.
To How to ID Good GM Optispark
