High HP LT1 owners...
Old Sep 22, 2002 | 08:59 PM
POLOVETTE 94's Avatar
POLOVETTE 94
Co-winner 2020 C4 of the Year - Modified
Default High HP LT1 owners...
What oil pan are you using on your stroker, supercharged, or nitrous injected LT1? How many of you are still using the stock pan? What about windage trays, baffles, etc. ? Is it worth a few hundred dollars extra when doing a rebuild? Thanks for the replies.
Darren
Old Sep 22, 2002 | 09:24 PM
95AquaC4's Avatar
95AquaC4
Default Re: High HP LT1 owners... (POLOVETTE 94)
Stock pan.
Old Sep 22, 2002 | 11:10 PM
The Green Rocket's Avatar
The Green Rocket
When I had the occaision to replace the pan I just went with another stocker. I don't remember what the issues were, but I seem to remember that some who have gone aftermarket had some fittment issues.
Thomas
Old Sep 23, 2002 | 03:10 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
I have the Canton 7.5 qt pan and use a high pressure high volume oil pump. You do have to modify the pan a little to clear the knock sensor on one side and you may have to modify the dipstick tube to fit the new pan properly, but that is just cutting it down a little. Other than that, it bolts right on and provides great peace of mind.
If you do any high RPM road racing, then I would definately suggest the bigger pan.
Old Sep 23, 2002 | 09:04 PM
Kehrer923's Avatar
Kehrer923
Default Re: High HP LT1 owners... (Vette92)
I used the canton 7.5 pan also with a melling HV oil pump. I had to clear the pan because my rods were hitting but i have 6.0 olivers. great pan though
Old Sep 24, 2002 | 12:02 AM
93LT1's Avatar
93LT1
Stock Pan
To High HP LT1 owners...
