Clear greasy fluid dripping off front driver side sway bar bushing (big one connected to chassis). It's kind of under the PS reservoir and I thought it might be that being as I flushed it a month or so ago but the PS fluid is red Red Line. This is clear as water but greasy slick. I don't know how at the location it could be brake fluid. Thoughts? It's a tiny puddle not an excessive leak.
Pretty sure it's old PS fluid that dripped all over when I removed the hose from the reservoir when I flushed the system. The cradle the reservoir sits in has fluid in it. The brakes are dry as a bone. Attached are some pics. Brakes, wet bottom of the PS reservoir and dried off bottom of reservoir.
