electrical problems need help on how to start!
Old Sep 23, 2002 | 03:29 PM
johndezman's Avatar
johndezman
Default electrical problems need help on how to start!
while in the garage working on something else i heard a relay or circuit breaker "pulsing" every couple of minutes. once it had my attention, i narrowed it down to something near the fan or fuel pump relay.
how should i determine what is "pulsing" and what is causing it?
have had a couple anamolies lately and this might be (or lead to) the root cause.
as always, many thanks for the help.
Old Sep 23, 2002 | 03:38 PM
JonM's Avatar
JonM
Default Re: electrical problems need help on how to start! (johndezman)
Year of your car would be?
The place to start would be to pull the fuse one at a time till you do not hear the clicking anymore
[Modified by JonM, 2:51 PM 9/23/2002]
Old Sep 24, 2002 | 09:50 AM
johndezman's Avatar
johndezman
84.
earlier this summer installed tpi/engine with upgrade to 87 computer. rest of the car stock 84.
Old Sep 24, 2002 | 12:48 PM
jfb's Avatar
jfb
If it is a relay clicking, then start unplugging relays one at a time until you find the relay.
Old Sep 24, 2002 | 03:40 PM
johndezman's Avatar
johndezman
Default Re: electrical problems need help on how to start! (jfb)
are there more than the two i've already mentioned?
Old Sep 24, 2002 | 03:53 PM
dlmeyers's Avatar
dlmeyers
Do you know the charging state of the battery? On some years, when the battery gets low, some relays for various lighting systems, or other circuits, will start cycling 'cause there is not enough power to keep the relay engaged. Not sure about 84's. Were the doors open?
dlmeyers 90 coupe zf6 3 speed shocks
To electrical problems need help on how to start!
