Lt1 engine swap
Old Feb 19, 2017 | 01:44 PM
gloup2020's Avatar
gloup2020
1st Gear
Default Lt1 engine swap
Can I replace my blown 1995 Caprice 9c1 5.7 lt1 engine with a Vette, Camaro, Pontiac lt1 5.7 engine? (I know some senors and hardware may have to be swapped)
Old Feb 19, 2017 | 08:55 PM
aboatguy's Avatar
aboatguy
Short block is the same.. Vette or F body aluminum heads will work...Its been a long time since i got rid of my 1995 SS but I believe the impala accessories are different and the fuel rail is different but your Impala accessories should bolt on a pre-1996 lt1 with no problems or empty holes. 96 and up have a cps but just ignore the empty socket and you should be GTG. with y or f body long block and b body accessories.
(Y body shortblock has 4 bolt mains)
