Corvette
Old Feb 20, 2017 | 07:04 PM
Vondkar's Avatar
Vondkar
3rd Gear
Default Corvette
Ac just stop blowing light is flashing on button
Old Feb 20, 2017 | 07:10 PM
antfarmer2's Avatar
antfarmer2
Welcome to the forum. Look on youtube it will self diagnose just push some buttons.
Old Feb 21, 2017 | 12:53 AM
Cliff Harris's Avatar
Cliff Harris
See this link for troubleshooting instructions:
Old Feb 21, 2017 | 06:20 AM
kenmohr's Avatar
kenmohr
What year
Old Feb 21, 2017 | 08:28 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Sounds like it may be low on Freon. Does the blower still work on heat?
Old Feb 21, 2017 | 12:13 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Yes, start here. But first, undo the negative cable on the battery for a few minutes as that resets the system.
If you restart the car and everything work then stops you will probably be low on Freon. If you then check the diagnostics you will probably get an "09" error code which means low Freon.
If you Freon is good check your cycling switch as that could have gone bad with time. They are about $15 at the parts store and take 6-7 minutes to swap.
To Corvette
