Slow, then fast starting on 93LT1
Old Feb 23, 2017 | 07:08 AM
krackenvette's Avatar
krackenvette
Default Slow, then fast starting on 93LT1
My 93 LT1 uses a 96 Opti, with a DELTEQ ignition. The rotor in the Opti is cut down just to hold the metal disc that spins within the opti sensor. I then loctited the hardware to keep things solid for many years. Sealed the opti etc. Solid. No issues for several years.
When I turn the key to turn over the engine, it is very slow then spins fast to start. It has always been a fast, spins over quickly, starting engine, till Friday.
The battery is new, and always on a tender when not in use. I do have extra Opti Boxes for the Delteq, as they are spares.
What would cause the engine to start like this? Tune has been the same too..
Thoughts.
Old Feb 23, 2017 | 07:29 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
My initial thought is that it has nothing to do with your Opti.
In previous life (mopars) that "slooooooww then fast spin to start" was caused by a combination of battery condition, starter condition and compression/timing and then fuel delivery.
Have you changed any timing elements lately or is your starter in good condition?
Old Feb 23, 2017 | 07:36 AM
krackenvette
Battery is a couple years old. It rarely gets driven and is mostly on life support, via the battery tender..
Timing has not changed in years, as it is a custom chip for the 396..
I am going to look at grounds and measure battery voltage during cranking.
Old Feb 23, 2017 | 07:48 AM
krackenvette
Need to find all the grounds on battery and drivers side..
Old Feb 23, 2017 | 11:18 AM
billschroeder5842
That is where I'd start; tenders tend and dont fix. That is why you are slow to start.
Get a new "full up" battery and watch the magic
Old Feb 23, 2017 | 11:29 AM
krackenvette
So charge it via regular charger, and what about while not being driven, disconnect battery?
Old Feb 23, 2017 | 06:32 PM
antfarmer2's Avatar
antfarmer2
I would look and see if you have a head gasket leak. Might be getting coolant in the cylinder.
Old Feb 23, 2017 | 07:17 PM
krackenvette
I dont think a head gasket is the problem.
Old Feb 25, 2017 | 08:26 AM
krackenvette
Took Vette off of battery tender, showed around 12.4 volts.
Let it set for a while, 2 hrs, and it was at 11.9. So, I trickle charged it 2A overnight, , barely over 12, at 12.1. I think the battery is toast. Weird, there is no date code anywhere, Sears Die Hard Gold. Just a bar code.
Called my SEARS rep, no joy, I bought it unattached to car, so it was open purchased couple years ago. She said, bring it in and she will fix it.
Old Feb 25, 2017 | 08:51 AM
billschroeder5842
Again, get a new battery and enjoy the rest of your weekend. Playing with chargers and tenders is wasted effort on your current battery. As you stated "It is toast"
Old Feb 25, 2017 | 08:58 AM
WVZR-1's Avatar
WVZR-1
I would think the battery has a "heat stamped" date code on the case somewhere!
Old Feb 27, 2017 | 06:10 PM
1993C4LT1's Avatar
1993C4LT1
Any luck?
To Slow, then fast starting on 93LT1
