Here's the "forward grounds" including the 2 at each kick panel inside car.
If you have the FSM, the right column info is a reference to images in the 8A-201 section of Book 2.
I was under the dash in the kick panel area, as I had taken down the knee bolster area. But, nothing was disconnected.
And, I did disconnect the square tubing going from the PCM to the frame while attempting to change booster, till I found actual hard brake pedal culprit. Is the ground down there?
See picture ground 10
8A-201-22 has a very good image of "where" you should be looking for G201
Found it, thanks, Last ground to check and it was clean and tight.. Battery is going back to SEARS... not happy.
it went from 13.2 with new battery in meter, to ensure correctness and tested in wall outlet, to 10.19 in 2 hours.
