Good point about the ECM and it's ability. I've often wondered why it didn't pull enough timing out to prevent pinging. I was planning on a dump tune once I got the cooling figured out, but now I'm thinking I should reverse the order!
Without a scanner, you can't know if it is pulling timing or not. Sure, if it is totally inop, the ECM will throw a code. So lets take the temperature as an example. In AZ it is 100 degrees but in the middle of a WI winter, it can be 10 below. If the sensor is sending a false reading of 10 below, it is plausible so it might accept it.
I see what you're saying. I should probably invest in one. And btw, I didn't realize "dyno" autocorrected to "dump." LoL
Reason: Add
Unless you have more money than God, I would.
My problem with the tune is that you really don't know what you are working with at all. It is all "he said, she said". That thing sounds like it has been jacked with so what it does is anybody's guess. Seeing as how high the compression supposedly is, I really don't like cranking up the timing via the distributor and hoping for the best depending on what your butt dyno says.
