ZF sevice question
Old Sep 24, 2002 | 02:39 PM
The Rex's Avatar
The Rex
Default ZF sevice question
What fluid do ya'll use in your ZF? I see in the tech section to use a GL-3 fluid and not to switch ratings up or down. I want to go synthetic, so is Mobil 1 compatible? If not what do you use? I don't want to damage the tranny (I've heard the nightmare stories) so will using a different rated fluid hurt the internals and why do they say stick to the one grade of fluid?
Old Sep 24, 2002 | 02:42 PM
fullboogie
Default Re: ZF sevice question (96 LTRex-4)
I had Mobil 1 all ready to go into my tranny when other members of the forum warned me not to do so. They've recommended ONLY the GM fluid, which is what I bought at the dealer last weekend. Seems to be the only way to go, according to these guys. I'm going with their recommendation.
Old Sep 24, 2002 | 02:49 PM
Silver89's Avatar
Silver89
Default Re: ZF sevice question (fullboogie)
You can either use GM P/N 1052931 5W-30
or
Castrol 10w-60 fully-synthetic. BMW P/N 07510009420. Available at BMW dealers.
This is on zfdoc.com, but more importantly, on the official ZF website.
Old Sep 24, 2002 | 02:52 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: ZF sevice question (Silver89)
or
:yesnod:
I don't have 6k to spend on a new tranny just because I used the wrong fluid. The two listed above are the only things that I'll put in my tranny.
I love Mobil 1, but I don't think it's worth the risk in this case.
Old Sep 24, 2002 | 02:53 PM
Scoob's Avatar
Scoob
I couldn't agree more. GM fluid only for me.
Old Sep 24, 2002 | 02:54 PM
silver & red CE's Avatar
silver & red CE
I wasn't happy with the smoothness of my ZF, so I swapped out the original factory fill with fresh factory fill, couldn't tell any difference. Then I switched to Castrol synthetic, the stuff from the BMW dealer, big difference. I will never go back to the factory fill, the ZF approved Castrol is the best.
Eric
Old Sep 24, 2002 | 02:57 PM
The Rex's Avatar
The Rex
Anybody know of anyone who used the wrong fluid & what it did to the tranny?
Old Sep 24, 2002 | 04:13 PM
DarkHalo's Avatar
DarkHalo
From: SCMR Rat Pack'r Charter Member, Inland Empire Chapter
Default Re: ZF sevice question (Nathan Plemons)
or
:yesnod:
Thats what Bill Boudreau also says and thats good enuff for me :blueangel:
Old Sep 24, 2002 | 05:35 PM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
ZF also recommends ATF according to ZF class 02F (found on website: http://www.zf.com ) This is according to an email from Matin Vogel of ZF.
I just replaced my fluid with GM fluid and it seems to not be quite as smooth as before. Next time I think I'll try the BMW stuff.
Dale
Old Sep 24, 2002 | 07:46 PM
silver & red CE
Default Re: ZF sevice question (Professor)
ZF also recommends ATF according to ZF class 02F (found on website: http://www.zf.com )....
Dale, I have looked all over that site for a page that says ATF is approved by ZF and found nothing of the sort. Do you have the link?
Eric
Old Sep 25, 2002 | 12:06 AM
Putter's Avatar
Putter
Default Re: ZF sevice question (silver & red CE)
I was at Funfest @ Mid-America. According, to Gordon Killebrew(sp) who is suppose to be the guru of C4 Covettes, the oil in the 6 speed transmission is Kendall 5w-30. It is sold to GM, who packages it in their containers and charges about $3.00 a quart. You can call Kendall and get the name of a dealer who can get the oil for you. :chevy
Old Sep 25, 2002 | 12:26 AM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: ZF sevice question (Putter)
There has been a great deal of conversation and postings about this issue for years on this board. Over this time there has been but a few knowledgeable answers. Those that seem to have experience with lubrication and the ZF transmission recommend the GM mix (GM 1052931, which BTW I thought was a GM / Texaco / ZF development),with a change frequency of at least 30,000 miles (or sooner with very hard use).
If you have every changed the oil, you will notice very quickly that the oil smells of additives that are not in engine oil.
What I can't believe is the constant argument about oil cost. Do you honestly want to take a chance or experiment with your $4,000 (rebuild cost) transmission? Do we really care about a dollar or two here?
Why would you think that a synthetic oil would be superior for use in a ZF? Does common usage regularly drive tranny temps over 300* ? Do we really need an oil that will last 50,000 miles or with average usage would a change with the oil that was literally designed for the transmission every few years foot the bill?
Pete
Old Sep 25, 2002 | 09:35 AM
silver & red CE
Default Re: ZF sevice question (PeteL)
Pete,
After switching from the factory fill to Castrol I noticed that my ZF shifted smoother, went into reverse easier, esp when cold. Granted this is subjective, but I'm not the only one to notice this effect. As for the high temp, my engine oil temp gauge doesn't ever read 300*, but almost everyone uses synthetic engine oil. Certainly the trans lube does reach high temps during hard driving, considering the power disipated by the trans and the proximity to the exhaust system, esp the cats.
Eric
Old Sep 25, 2002 | 10:02 AM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
http://www.zf.com/zf_group/produkte/...E_englisch.pdf
Try here and scroll down to class 02F.
Dale
Old Sep 25, 2002 | 10:11 AM
silver & red CE
Dale,
Thanks for the link, but that page says the transmissions are truck and bus applications. I don't understand how it clears ATF for the Vette's ZF. Not trying to be a PIA, just want to understand.
Eric
Old Sep 25, 2002 | 10:41 AM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
That was the info I got from Martin Vogel at ZF. I asked him what they recommended and he sent me a list with the GM, BMW, and class 02F ATF. There is a link to his email on the ZF site but I doubt he would appreciate being inundated with email messages all asking the same question.
Personally, I would not put ATF in my tranny, but that's me. I've had trouble with other manual trannys (not ZF) that specified either GL5 or ATF. With ATF they would not shift right and had trouble syncronizing while shifting. Granted, the ZF is a far better designed tranny that the others so if they recommend it ...
I've looked thru all of the pdfs in their lube section and have never found anything on the S6-40 in particular which is why I emailed ZF in the first place.
Dale
Old Sep 25, 2002 | 10:49 AM
T1Kilr's Avatar
T1Kilr
I will go with ZFDoc's recommendations personally.
[Modified by T1Kilr, 9:50 AM 9/25/2002]
To ZF sevice question
Old Sep 25, 2002 | 11:45 AM
ZZZASY's Avatar
ZZZASY
Don't know where you are getting $3 a quart from. My dealership wants $13 a quart.
Old Sep 25, 2002 | 11:50 AM
Nathan Plemons
Default Re: ZF sevice question (ZZZASY)
For the GM or the BMW? GM from the local dealership around here wants $8.
Old Sep 25, 2002 | 02:13 PM
all4c4lt4's Avatar
all4c4lt4
Here's the reply to the email I sent to Martin Vogel at ZF, I informed him that I had a 96 mn6:
"Recommended lubricants and oil drain intervals for
ZF S6-40 transmission used in GM Corvette
1. recommended lubricants
- GM oil part no. 105 293 1
or
- BMW oil part no. 075 100 094 20
(Castrol Formula RS SAE 10W60)
or
- ATF according to ZF lubricant class 02F
(ZF list of lubricants TE-ML 02)
2. recommended oil drain intervals
30,000 - 40,000 miles (48,000 - 64,000 km)
ZF Friedrichshafen AG
Central Research and Development
Lubricants and Chemical Laboratory
Martin Vogel
88038 Friedrichshafen
email: martin.vogel@zf.com"
I doubt he wants a flood of emails regarding this, so I just posted his answer to my question. Received it about 1 month ago.
