Coolant Leak--Need Some Help
Old Mar 7, 2017 | 04:57 PM
Wayne88's Avatar
Wayne88
Originally Posted by 4xcontractor
I've have a leak in almost the same area, bought a pressure tester from HF to locate it, Ck with a mirror if you can at the lower water pump bolt on that side right above the timing bracket. Mine is weeping out between the pump and block, not easy to see, ends up running along the cross member before hitting the ground.
Looks like you are exactly right.
I got the pressure tester, and after pumping it, the coolant was oozing out from the WP gasket and trickling down. It is easier to detect with the pressure pushing it out.
Old Mar 7, 2017 | 06:29 PM
Gibbles's Avatar
Gibbles
Be happy it was not the heater bypass, i just shelled out $120 for a new one...
​​​​​​​The insides had fractured into little pieces and it was leaking all over the place.
Old Mar 7, 2017 | 07:20 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default water pump gasket leak
Originally Posted by VikingTrad3r
don't forget to get prepared and the exact rate torqx bit size for the hidden screw under the AC
Good suggestion for the torx bit that is hidden. I replaced the water pump many years ago because of leak from the weap hole. Several years later had a leak very similar to yours and discovered it was from the driers side of the water pump. I did not want to do all the dismantling of parts and tried tightening up the bottom water pump bolt with just a bit more than the recommended torque. It worked. This was several years ago now and the leak has not came back on my 1985. If it does I will have to replace the water pump gaskets.
