92 performance problem
Old Mar 5, 2017 | 10:13 AM
flyingmonk's Avatar
flyingmonk
5th Gear
Default 92 performance problem
I have a 92 LT1 That Jerks when I punch the gas. It had been sitting in the garage for 2 years because it needed a new Optispark. Idles great and runs fine otherwise.
Things that have been done:
. Optispark
. Spark plug wires
. fuel pump
. fuel filter
. fuel pressure is fine at idle and under load
. Ohms on injectors are within range
. cleaned throttle body
I'm starting to lean towards O2 sensors or maybe the cats?
Old Mar 5, 2017 | 10:17 AM
antfarmer2's Avatar
antfarmer2
O2s and pull your knocks while your under there for a proper flush.
Welcome to the forum.
Old Mar 5, 2017 | 10:24 AM
flyingmonk's Avatar
flyingmonk
5th Gear
Thanks for the quick reply. I pulled the knock sensors and flushed it when I replaced the optispark. I'll go ahead and replace the O2s and report back what happens.
Old Mar 5, 2017 | 07:16 PM
FAUEE's Avatar
FAUEE
Did you get the plugs/wires in the right order? Having the firing order wrong can cause it to feel like that.
Old Mar 5, 2017 | 10:16 PM
aklim's Avatar
aklim
Does it catch up when you WOT it quickly?
That is a "Dr Feelgood" test. Makes you feel good but does nothing to identify if the injectors are crudded up or partially crudded. Having sat for 2 years, I'd bet there will be some flow improvement if you have it cleaned and tested. Mine show improvement and I have never let it sit for more than a couple of weeks.
Did you take the top plate off, IAC, IAC housing and clean the passages? New gaskets? Did the IAC counts show that you are having air leaks anywhere? Scanner should show about 30 counts, give or take with everything but the motor off and engine at full operating temp. If it cannot, turn the screw out, rev and re-read. If you are all the way out and still cannot achieve the counts and getting 0, you have an air leak.
Old Mar 5, 2017 | 10:26 PM
aklim's Avatar
aklim
Would the O2 reading affect WOT?
Old Mar 6, 2017 | 12:27 PM
antfarmer2's Avatar
antfarmer2
My 94 would fall on it's face buck and fart then run great once it got caught up.
Old Mar 17, 2017 | 06:42 PM
flyingmonk's Avatar
flyingmonk
5th Gear
Just got around to replacing the O2 sensors. They fought me every step of the way but it fixed the problem! Thanks everyone!
To 92 performance problem
