L-98/LT1 Starter
L-98/LT1 Starter
Hello, has anyone by chance used an lt1 starter on there L98 I have an 87 and want to change to a smaller starter, there's a forum member with a 95 I'm going to purchase if it'll fit my l98 has anyone done this? Thank you!
When I installed headers on my '87, I bought this Hitachi-style starter from Summit Racing. This was a bolt-in and I didn't need to make any changes to the wiring. True "plug-n-play". This starter is also "clockable" so you can turn the solenoid to add clearance where needed.
The size is comparable to the later smaller size starters from '89-on. The full-size starter that was in my '87 would have been a royal PITA to re-install after the headers went on.
I think there was a thread here about using the later LT1 starters in the earlier C4's and it mentioned it required changing the length of some of the wires. Given the price of the starter in the link, you might be better off going with a brand-new starter compared to a used starter that may require some modifications to work properly.
One other concern may be the number of flywheel or flexplate teeth from the '95 so that it would work with the '87. The Summit starter works with both the 153 or 168-teeth components found on the '87. Not sure how a '95 starter would work.
Post the snapshot of the connection arrangement and I'd think it much easier to answer your question.
