1984 corvette air pump delete
Old Mar 9, 2017 | 06:35 AM
Sephiroth1991's Avatar
Sephiroth1991
Default 1984 corvette air pump delete
Ok here is the deal my air pump has went out and the pulley is wobbling and I have to replace my power steering pump to get to it I have to take the air pump off but if I'm taking it off can I jus delete it some how. Like can I use a different size belt. I also heard if you delete the air pump it will give you a little more hp. Tips on doin this will help
Old Mar 9, 2017 | 07:42 AM
Gibbles's Avatar
Gibbles
You can just remove it, then get a shorter belt.
I don't remember the size, but a few minutes doing a google search found the size for me originally.
I now have billet underdrive pulleys, so my belt size changed...
if all else fails, take the original belt, slice it, install, tape, mark, and measure how long your result is.
​​​​​​​It might take a few tries, just don't damage the package so you can exchange.
