1985 Manual misfiring
Old Mar 20, 2017 | 12:02 PM
  #61
Bfenty's Avatar
Bfenty
2017 C4 of Year Finalist
Originally Posted by aklim
Timing light and a couple drops of paint to make a stripe on the harmonic balancer
I know you get what you pay for, but I'd rather not buy a super-expensive timing light if possible. Amazon is my friend, as I get amazon points and gift cards from work all the time. Can someone recommend a decent one that won't break the bank?
Old Mar 20, 2017 | 12:05 PM
  #62
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
just get a cheap one that has the positive/negative battery clamp and the spark plug wire clamp.
its not rocket science u dont need any bells or whistles
Old Mar 20, 2017 | 12:06 PM
  #63
Bfenty's Avatar
Bfenty
Cool. They go from $20 all the way up to $150, and I couldn't see a difference at all.
Old Mar 20, 2017 | 12:19 PM
  #64
aklim's Avatar
aklim
If you get the basic timing light, it might be harder to read for older eyes so I'd get one which can advance your timing reading. So when I turn mine on, not only do I get a tach, my light flashes when it is at the 6 degree mark. That said, I can advance my timing light so that when the light comes on, the mark is at the 0 mark, making it easier. Especially when you want an odd degree like say 5 or 7 or 9 degrees.
Old Mar 20, 2017 | 12:32 PM
  #65
Silver85's Avatar
Silver85
ak is right. call jon.
85 has DIFFERENT injector lbs than the rest. i belive its 24lbs. but call him and ask!!
Three votes for this.
$190 for a rebuilt set from FIC. I wouldn't even worry about what you have in their now, go ahead and replace them. Mine were blue.
Old Mar 20, 2017 | 01:04 PM
  #66
Tod Stiles's Avatar
Tod Stiles
Some new info-I got the gauges working, and I'm getting a whopping 8 MILES to the gallon! whoop!
I feel like that's a little low considering I'm driving it like my grandma (who is not the little old lady from Pasadena).
I'm pretty sure it's related to the misfire. I'm actually not getting any codes on the ECM anymore (that's a good thing, right?) so I think as far as it is concerned, we're running pretty well. I still haven't done the compression test or checked timing, have to buy the stuff to do that first. Just thought the high fuel consumption might be a clue to what's happening.
Possible. Did you reset the fuel usage? I get about 8-10 when I've been working on the car, a bunch of idling and quick trips around the block bring that number down. When I'm not messing with it I can manage 12-15 around town and 20-21 on the highway. That is if I stay out of the gas!
Good to hear you're making progress. Get all the basics done/fixed/set and it'll be easier to find bigger problems if there are any.
Old Mar 20, 2017 | 01:09 PM
  #67
aklim's Avatar
aklim
I'd manually check it and not just rely on the gage
Old Mar 20, 2017 | 02:08 PM
  #68
Bfenty's Avatar
Bfenty
Manually check the fuel level? I'm sorry I'm not sure I understand...
Old Mar 20, 2017 | 02:12 PM
  #69
Silver85's Avatar
Silver85
I think he means to manually calculate gas milage. The computer numbers are notoriously wrong.
Old Mar 20, 2017 | 02:14 PM
  #70
Bfenty's Avatar
Bfenty
ooo...sorry that makes sense. I think I mentioned in another thread where my gas gauge is showing full 100% all of the time and got confused.
Old Mar 20, 2017 | 03:13 PM
  #71
aklim's Avatar
aklim
Absolutely. Mine has some fantastic mileage which I know I don't get in my wettest dreams
Old Mar 20, 2017 | 03:15 PM
  #72
Bfenty's Avatar
Bfenty
Great...so you're telling me that 8mpg is the OPTIMISTIC number...lol.
But seriously, thanks, I'll try to calculate manually. Although with all the testing of stuff I'm doing I know it's gonna kill the MPG anyway.
Old Mar 20, 2017 | 03:16 PM
  #73
aklim's Avatar
aklim
Cruise mileage has the least amount of variables
Old Mar 20, 2017 | 03:17 PM
  #74
Bfenty's Avatar
Bfenty
The misfire also makes it nearly impossible to drive with overdrive on-that RPM range is right where the misfire is the worst. I'm sure that doesn't help either.
Old Mar 22, 2017 | 11:40 AM
  #75
Bfenty's Avatar
Bfenty
Took the car to good mechanic I know-he drove it for about 2 minutes and came back and told me he thinks the problem is an aftermarket cam that's wrong for the car. He says it's running on all 8 cylinders but that cam is throwing the timing way off, especially in lower RPM range. from 1500-2000 is really rough, but by 3000 RPM the engine runs near perfectly.
This goes well beyond my current skill level. I'm willing to do the repair, but...
1-What is the difficulty of swapping the cam out? Anyone aware of a good writeup for this job?
2-How accurate do you think this diagnosis is? I highly trust this mechanic and he's very good, but I still am looking for opinions.
3-While I'm taking all of this apart, any other suggestions for things to take care of?
Thanks guys!
Old Mar 22, 2017 | 11:53 AM
  #76
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Swapping a cam is tantamount to out-patient surgery. Doable and relatively minor, but still something gets cuts, bleeds and needs to heal.
Before you put your car under the knife, can you post a decent video of your engine running through the RPM range. Sound is super important along with the video. We need to see idle, increasing RPMs and when it "smooths out." Please shoot video of the engine itself and not from the driver seat.
You mechanic is undoubtedly honest and knowledgeable, but these cars are over 30 years and unless this guy has been working on them for that long, it may be real easy to make a misinterpretation.
Old Mar 22, 2017 | 11:59 AM
  #77
Bfenty's Avatar
Bfenty
Sure thing. I'll try to get that posted later today.
It's considerably more pronounced when going down the road and the engine is under load, rather than just revving in neutral.
There have been a lot of hands on this car, so it's a mystery if someone has messed with something else.
Thanks for being willing to take a look! You guys are the best!
To 1985 Manual misfiring
Old Mar 22, 2017 | 12:01 PM
  #78
Silver85's Avatar
Silver85
If I were in your shoes I would spring for a scan tool to really see what's going on. Looks like a mt2500 on ebay used is in the $150 range? I'm betting you can turn around and resell it when you are done with it for about the same amount.
Old Mar 22, 2017 | 12:06 PM
  #79
VikingTrad3r
Oil Producer
Thanks guys!
you can definitely do it. I assume the car is not a daily driver.
realize though, that this will create a bunch of while you're in there type of things. And that is OK. But the job is going to become more than just a cam swap. It's important to be honest about that. Fasteners are going to break hoses will be discovered to be rotten. gaskets will have to be replaced, they'll be many things that will be fun and enjoyable to do if you have the time and financial resources to purchase the required components.Personally I would enlist the help as offered by Bill and others. I would take as many videos as possible and post them here.Normally I would recommend that you invest $40 in the ALDL cable and use the free tuner pro RT software. however the 1985 car does not possess the capability of being recorded at normal operating conditions. The only way to view the 1985 car on a scanner, is what's called field test mode, and unfortunately field test mode commands dez. M to make some changes. I believe it retards timing as well as holds an idol to 1000 RPM and I believe it also gets rid of the knock sensor monitoring. There are other things it does as well. Unfortunately the 1985 computer Will not allow us to view it and scan it while it is in normal operating mode. The reason this sucks, is because there's no way for us to record a data trace well you're car is experiencing the problem is. It may still experience the Misses well it is in field test mode at 1000 RPM, but so many of the other sensors are being told to hold certain levels that we cannot get a clear picture of what is happening during normal operating procedures. I discovered this with my 1985. starting in 1986, you can view the computer and record what's happening in the car well normally driving down the road.All this to say that before proceeding I would take as many videos and upload them to YouTube using your iPhone or your android phone and accept the help of guys like Bill.
edit: furthermore I would like to agree with Bill, your mechanic maybe trustworthy and I'm sure he is. However if he does not have experience working on C4 Corvettes, specifically early ones with the L 98, unfortunately honestly doesn't matter. You may have somebody close by you on this forum that might be able to help dial it in. And well that person may not be a professional mechanic, the specific experience with the C-4 Corvette is more valuable than being a professional mechanic. I would reach out for help on the forum for people close to your proximity.
Old Mar 22, 2017 | 12:41 PM
  #80
Bfenty's Avatar
Bfenty
I had eventually planned on taking the engine apart and replacing gaskets, cleaning things out, etc, anyway-sounds like this might be the opportunity to do that. I've never done deep engine work before, but I'm confident if I take my time and do the research beforehand, I can do pretty much anything on this car.
I also happen to be a professional wedding videographer, so...recording audio/video isn't an issue! Small victory there, at least.
