Adding O2 sensor to aftermarket exhaust
Old Mar 12, 2017 | 08:20 PM
Bfenty's Avatar
Bfenty
2017 C4 of Year Finalist
Default Adding O2 sensor to aftermarket exhaust
Posted in my misfire thread but thought this might warrant another thread.
Previous owner installed aftermarket exhaust and did not install the O2 sensor! I'm trying to install it but want to know where it needs to go. How exact is the placement? I know it goes drivers side, before the catalytic converter. This exhaust doesn't have catalytic converters, it's just straight pipe with resonators. Can someone help me figure out where to place? Thank you!
I think this is the O2 sensor but it looks busted.
You can see the aftermarket exhaust going down here. This is the drivers side.
Old Mar 12, 2017 | 08:52 PM
Silver85's Avatar
Silver85
Do you have the bung for it? If so, anywhere before the cats that you can still thread the sensor in will work I believe.
Old Mar 12, 2017 | 09:22 PM
Bfenty's Avatar
Bfenty
That's just it, there aren't any cats.
Old Mar 12, 2017 | 11:37 PM
aklim's Avatar
aklim
Assuming it is an L98 and Assuming that there is only 1 wire, the answer would be as close to the branch of the manifold as possible.
Old Mar 13, 2017 | 07:59 AM
Bfenty's Avatar
Bfenty
So, next question. Would a universal o2 sensor bung work? Like this one? Or so I need something more specific?
https://www.carid.com/weapon-r/o2-se...57&url=2481118
Old Mar 13, 2017 | 08:03 AM
aklim's Avatar
aklim
Shouldn't be a problem for you.
Old Mar 13, 2017 | 08:09 AM
Bfenty's Avatar
Bfenty
awesome, thanks for all the great info guys! I'l try to get that on later this week and post back with results.
Old Mar 13, 2017 | 08:12 AM
WVZR-1's Avatar
WVZR-1
You should be able to buy the bung required "locally" - you shouldn't need to order anything that requires paying shipping.
You need to look for a PURPLE WIRE - it should be in the conduit @ the left side of engine where the OIL TEMP wire, COOLANT TEMP wire etc is routed. That's of course if the PO didn't modify all of that either.
Old Mar 13, 2017 | 08:14 AM
Bfenty's Avatar
Bfenty
I've already bought the O2 sensor, I'll probably just take that down to my local exhaust shop and let them install. I'm pretty sure they'll have everything else required.
Old Mar 13, 2017 | 08:31 AM
aklim's Avatar
aklim
Sensor or the bung? Any chance of an exchange of sensor to the heated ones?
Old Mar 13, 2017 | 10:06 AM
Bfenty's Avatar
Bfenty
Heated ones?
Old Mar 13, 2017 | 10:31 AM
aklim's Avatar
aklim
Heated ones?
They have heated o2 sensors. Just in case the exhaust gets cold and the sensor falls out of range.
Old Mar 13, 2017 | 10:32 AM
Bfenty's Avatar
Bfenty
Oh. I already bought one, I don't think it's a heated one, but honestly it rarely gets cold where I live...
Old Mar 13, 2017 | 10:35 AM
ghoastrider1's Avatar
ghoastrider1
Also, they make o2 wire extensions if you need one. Push come to shove, you can always go to a junk yard and get a short piece of exhaust that can be welded into yours.
Old Mar 13, 2017 | 11:12 AM
vader86's Avatar
vader86
The purpose of the heated O2 is so that the engine doesn't drop out of closed loop (where the ECM reads the O2 voltage input to adjust fuel) and into open loop (where it reads Coolant temp and a pre-programmed table). Open loop makes it run richer and use more fuel.
The cats keep the heat in the pipes better so the sensor doesn't get too cool. (cold is relative) It doesn't matter how hot it is in your area. Mine drops out at idle in Alabama summer sometimes.
Its not a requirement to put it in, and I doubt it'll make much difference for you unless the motor is heavily modded, but if youre doing one then it can't hurt.
Old Mar 13, 2017 | 11:14 AM
Bfenty's Avatar
Bfenty
If I hadn't already ordered it, I would get a heated one. Thanks for the advice though, if I continue to have issues, I will possibly replace. it's a cheap part.
Old Mar 13, 2017 | 12:13 PM
aklim's Avatar
aklim
I agree with you but since he needs an O2 bung, I have a sneaky suspicion they took out the cats and maybe cheap headers.
To Adding O2 sensor to aftermarket exhaust
Old Mar 13, 2017 | 12:14 PM
Bfenty's Avatar
Bfenty
There are no cats at all on this exhaust. So that could be a problem then.
Old Mar 13, 2017 | 12:17 PM
aklim's Avatar
aklim
I don't know. I'm not there so I cannot see if you have a cat or whether he took it off or hollowed it out.
Old Mar 13, 2017 | 12:35 PM
c4cruiser's Avatar
c4cruiser
From the pics, the exhaust manifold look to be a stock one. If the "aftermarket exhaust" is simply a Y-pipe without the pre-cats, the O2 sensor should still be put in the OEM location. That would be on the driver's side about 2-3 inches below where the pipe attaches to the manifold. Any good muffler shop should be able to drop the Y-pipe and weld in an O2 sensor bung.
I don't think a heated O2 sensor would make any improvement. To install one, the OP would need to find a switched 12v source to provide power and a wire from that heated sensor to a good ground. The C4 never had a heated sensor, so it would take some searching to come up with a sensor that would thread into the bung and work like a GM regular sensor.
