Figured out the "white smoke" issues...
Upon inspection and disassembly it turns out I have TWO CRACKED CYLINDER HEADS!!
So my question may be obvious, can I just use ANY "Non Vortec" Small Block Heads? OR is there anything special about these cracked stock heads? (Sender locations, issues because of the crossfire setup, etc).
Also I know the car isn't desirable BUT should I be worried about any "numbers matching" stuff?
Thanks again for your help...
Steve
Aluminum heads from '86-on, casting # '113, are a popular swap for the 40lbs weight savings; common, cheap, and basically a direct swap. The chamber size drops from 76cc to 58cc, so with a stock .021" shim gasket your static compression will rise from ~9.1 to ~11.25. However, about a point of that will be "absorbed" by the higher heat dissipation properties of aluminum. You'll gain a little power...essentially the same as running 10.25:1 static with iron heads. Shouldn't cause any detonation issues with the mild stock cam, thanks to the wonders of dynamic compression, but just something to be aware of.
If you're after a bit more flow, as many Crossfire owners are, Vortec heads are in fact a pretty decent option, being thick on the ground, flowing better than any early C4 heads, and cheap...but you'd have to add a Vortec-style intake to the parts list, which means ditching the Xfire.
Or, you may take this as an opportunity to upgrade to some aftermarket heads - there's a zillion out there at every price point. Well-flowing heads are going to be at the very core of any performance build, so if you think you may lean that direction at some point in the future, now would be the "cheapest" time to do it!
Good thing is you've got options. It's a slippery slope to project car status, but it can be a helluva lot of fun! And if you're just looking to keep driving it, nothing wrong with a cheap reconditioned set of '113s.
Consider a Renegede intake manifold. All the new heads in the world wont make a difference if the intake does not flow enough to support.
The stock intake manifold is a choke monster.
roller cam
It may seriously be your best option budget-wise, along with getting a little bump in performance & reliability. Not too shabby! If you're not real worried about building big power later on, I'd go this route.
Keep in mind for shopping, going from two piece to one piece rear main will require a different flywheel.
I decided its kinda neat...
I did headers, 80lb injectors from a 454, edlebrock heads, Renegade intake, mild cam, roller rockers, headers, and a 3in exhaust with flowmaster 40's.
Engine is running off of an eblflash ecm, it was a little bit of a learning curve, but i like that i did everything my self.
The car flys, i have a video of me not breaking the law, but the car is a wild good time now.
i had the throttle down maybe 40%
I thought about posting some others, but i decided that would be a bad idea...
https://youtu.be/EYOFnNe4tEM
Oh, and if you live in California, the answer is probably gonna be yes
