Code 33 when cold
Old Mar 15, 2017 | 08:20 AM
R3DH0TV3TT3's Avatar
R3DH0TV3TT3
Default Code 33 when cold
I wanted to post my results of chasing a DTC 33 on my 89. The car would run normal when the outside temperatures was above 50 or if I let the car warm up before driving it. On cold mornings I would get a CEL and the car would want to die at stops. After it got to operating temperature I could restart the car and I'd have no issue or CEL.
I followed the diagnostic chart from the FSM and everything checked out until I put the MAF in the freezer. I went through the tests again and it finally came down to replacing the MAF. I have a Wells SU145 and found a hairline crack in the circuit board. Best I can figure is that with the car heating up the cracked expanded enough to make contact and allowed it to run correctly.
Old Mar 15, 2017 | 12:04 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Good catch- who would have thought that?
Old Mar 15, 2017 | 10:21 PM
R3DH0TV3TT3
I have to tell you it was a very long frustrating journey. Once I finally convinced myself it was the MAF it was like driving a whole new car.
Old Mar 16, 2017 | 09:09 AM
Bwbob's Avatar
Bwbob
Thats some good troubleshooting. You recreated the conditions and tested. I too like to test things even though i should "know" the answer because more than once there is a factor that i didnt take into account.
To Code 33 when cold
