87 vette transmission
Old Sep 25, 2002 | 04:00 AM
gotboost's Avatar
gotboost
3rd Gear
Default 87 vette transmission
I have a buddy that has a 87 with the 4plus 3 trans. and I was wondering if he can get the shifter boot and the piece that is with it too?
Thanks for the help.
Old Sep 25, 2002 | 04:38 AM
VetteRacer282's Avatar
VetteRacer282
Default Re: 87 vette transmission (gotboost)
For the boot, any local upholstry(sp) shop should be able to make one for a few dollars.
As for the other part I am unclear what you mean?
Goodluck
Matt
Old Sep 25, 2002 | 09:34 AM
vader86's Avatar
vader86
Theres a place in Spartanburg or Greenville that does a really good job, ill try to find out what the name of the place is.
:seeya :seeya
Old Sep 25, 2002 | 10:04 AM
JonM's Avatar
JonM
Just about any Corvette parts distributor has them.
http://www.tld-corvette.com/ Part # 629842
Price: $34.00
Old Sep 25, 2002 | 12:43 PM
gotboost's Avatar
gotboost
3rd Gear
He told me that it is the shifter boot and there is a linkage that is conected to that and it goes to the transmission. I hope this might have helped better. This is what he told me. Is there a shifter boot under the console.
[Modified by gotboost, 4:52 PM 9/25/2002]
Old Sep 25, 2002 | 12:44 PM
JonM's Avatar
JonM
:confused: need more info
Old Sep 25, 2002 | 01:51 PM
Maximus9000's Avatar
Maximus9000
I think he's talking about the reverse lockout linkage. The top of the boot is attached with staples on the factory ones. This is a ring that slips over the shifter and is pulled up to put it into reverse. I replaced my boot with one from Zip. The boot was attached to a plastic base plate that was poorly made but the boot is fine, the plastic plate wouldn't allow the consol to sit flush, and the holes didn't line up with the console top. I took off the plastic base and attached the stock steel plate with weather stripping cement to the boot and used the same cement to attach it to the lockout ring. Looks purfect and has been fine ever since. There is a front and back to this boot and the base plate, so they needs to be put on correctly or it will restrict the throw on the shifter. Even when I got it right it was tight in one direction, but after a bit of use it stretches and loosens up. You may have to play with it a little to get it right. Get it to work first then use the cement. When you get into it you'll see what I mean.
Old Sep 25, 2002 | 10:05 PM
Rich B.'s Avatar
Rich B.
There is the leather boot that you can see under the ****; a new one from GM runs ~$125...
There is a 3-hole rubber bellows thingy at the front of the shifter cavity that the 3 shift rods go through; no longer available...
Old Sep 30, 2002 | 01:15 AM
gotboost's Avatar
gotboost
3rd Gear
Default Re: 87 vette transmission (Rich B.)
Thanks for the help guys
To 87 vette transmission
