Opinions please, check out this plug
Old Sep 25, 2002 | 09:52 AM
L98Terror's Avatar
L98Terror
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Default Opinions please, check out this plug
Old Sep 25, 2002 | 09:55 AM
Kevin McGrade's Avatar
Kevin McGrade
Default Re: Opinions please, check out this plug (L98Terror)
Looks to me like you need a LT-1 to play with :jester
Old Sep 25, 2002 | 09:57 AM
ZylaRace's Avatar
ZylaRace
How many miles on those injectors? Do you use a fuel additive?
Ash build up tells me ther is something in the gas, or the fuel is not fully vaporized.
Change your brand of gas.
Old Sep 25, 2002 | 09:58 AM
Raistlin's Avatar
Raistlin
do all the plugs look like that? or is it just the one cylinder?
Old Sep 25, 2002 | 10:01 AM
gtsyellow's Avatar
gtsyellow
Default Re: Opinions please, check out this plug (Raistlin)
looks somewhat oil fouled from blow by then cylinder combustion was burning it off the electrode & leaving some grime. it wouldn't suprise me if you had a fractured ring in the cylinder that came out of.
Old Sep 25, 2002 | 10:03 AM
jessejames's Avatar
jessejames
Could you be running too high a heat range to compensate for some oil fouling?
Old Sep 25, 2002 | 10:22 AM
Nathan Plemons's Avatar
Nathan Plemons
You might also try a non platinum plug. I've heard and I can in no way verify this that platinum plugs tend to run cooler, and will foul out quicker, especially if the car isn't in perfect tune.
Old Sep 25, 2002 | 10:58 AM
ittlfly's Avatar
ittlfly
Looks like deposits and some oil fouling. Change the brand of gas and run a compression check of that cylinder.
[Modified by ittlfly, 5:14 PM 9/25/2002]
Old Sep 25, 2002 | 11:11 AM
L98Terror's Avatar
L98Terror
That was the #3 the #1 had some build up but the other 6 looked great.
See how the arm looks pushed over a bit(Melted), I am running like a 120 shot of N2O.
It was funny most of the plugs looked like they just came out of the box.
It is pushing a little oil maybe just # 1 & #3. Compression looked good in the #3 but looked down in # 2
Old Sep 25, 2002 | 11:12 AM
L98Terror's Avatar
L98Terror
Default Re: Opinions please, check out this plug (ZylaRace)
Injectors 135k They were cleaned and balanced about 30k ago
Fuel Additive just N2O :D
Old Sep 25, 2002 | 05:59 PM
GusBustamanteJr's Avatar
GusBustamanteJr
WHY DIDNT YOU SAY NITROUS ON THE FIRST POST!!!!!!
CAN YOU SAY TIME BOMB>>>>TICK TOCK TICK TOCK!!!!! :nopity
Old Sep 25, 2002 | 06:01 PM
L98Terror's Avatar
L98Terror
Default Re: Opinions please, check out this plug (GusBustamanteJr)
Explain
Old Sep 25, 2002 | 07:00 PM
gtsyellow's Avatar
gtsyellow
rule #1 NEVER RUN PLATINUM PLUGS ON NOS !!!!! buy the $1.99 NGK Fr6 if your running no2, FR5 if your not. the nitrous and n02 don't really get along, also that oil definatly could be from a cracked ring. no2 on a platinum plug that's probably hot will create some insane cylinder heat. that on top of GM's cast iron top ring...do a leak down test, not just compression, if the ring is just fractured it will hold some compression but it won't hold up to a leak down.
Old Sep 25, 2002 | 07:07 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The fact that it's two adjacent cylinders that cause the same symptom is a little suspicious, even with good compression check.
Any chance of cross-fire in the wires??
Old Sep 25, 2002 | 07:36 PM
bill mcdonald's Avatar
bill mcdonald
Default Re: Opinions please, check out this plug (gtsyellow)
the nitrous and n02 don't really get along.
what?
:confused:
Old Sep 25, 2002 | 07:40 PM
scorp508's Avatar
scorp508
What should he run if he's running N2O. No nitrite in this engine.
Old Sep 25, 2002 | 07:49 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: Opinions please, check out this plug (65Z01)
Like GTSYellow said, NEVER run PLATINUM PLUGS with NITROUS. I have some plugs that look worse than that from detonation under juice. Unfortunately the pistons looked worse. If I were you I would definately do a leak down test and buy some copper plugs and gap them at 35. The plug could just be loaded up from the electrode being melted. If that is the case, I would consider yourself very lucky.
To Opinions please, check out this plug
Old Sep 25, 2002 | 08:07 PM
bill mcdonald
Default Re: Opinions please, check out this plug (Vette92)
What plugs do you run Chris?
Old Sep 25, 2002 | 11:22 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: Opinions please, check out this plug (bill mcdonald)
I usually run Autolite 103 plugs (2 stages colder than stock) gapped at 35. Right now I have a set of NGK TR5 (stock range) in there gapped at 35. You can run a 100 shot on stock range plugs as long as they are copper core. If you run a 150 on stock heat range plugs it is probably a good idea to run some race gas mix. I have also run Autolite 104's and stock heat range Autolite 106's.
Chris
Old Sep 26, 2002 | 12:39 AM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Looks like build up from detonation to me. Do a search of plug wear on the web and you will find lots of pictures like this. That metal is comming from your combustion chamber parts.
