Compression test results Before and after
Old Sep 25, 2002 | 12:23 PM
L98Terror's Avatar
L98Terror
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Default Compression test results Before and after
What do you think
5/12/1999 108k 9/25/2002 135k
1 205 219
2 208 200
3 200 232
4 210 222
5 210 231
6 214 215
7 210 220
8 210 225
:confused:
Old Sep 25, 2002 | 12:38 PM
jfb's Avatar
jfb
Default Re: Compression test results Before and after (L98Terror)
Looks ok for 135k miles. The difference from highest to lowest compression is on the high side, but not worth doing anything about it.
Old Sep 25, 2002 | 12:42 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Compression test results Before and after (jfb)
How did they increase? Ho/cold engine? Different guage?
Old Sep 25, 2002 | 12:48 PM
L98Terror's Avatar
L98Terror
Default Re: Compression test results Before and after (ski_dwn_it)
Strange huh!!!, Same gauge, Vette was cold this time can't be sure about last time but I'd figure cold as well otherwise I'd burn the poopie out of my hands.
The #3 had the highest and was the one I pulled the funky plug out of. maybe it'e pushing oil causing a better seal or filling the chamber a little????
Old Sep 25, 2002 | 12:49 PM
scorp508's Avatar
scorp508
If you want to do it hot also gimme a buzz and I'll help.
Old Sep 25, 2002 | 01:27 PM
smallblock's Avatar
smallblock
did you get another gauge? if so maybe the calibrations are a little different.#2 picked up tho..........good.
Old Sep 25, 2002 | 02:10 PM
Nathan Plemons's Avatar
Nathan Plemons
A compression test doesn't tell you a whole lot in the whole scheme of things. It can't tell you anything really more than how your cylinders compare with each other.
You really need a leakdown test for good info. This will test to see how the entire cylinder seals. I did a compression test on mine, in which case the motor is perfectly healthy and it made right around 140 on all cylinders. The leakdown test showed a different story however, to the tune of 50% leakdown on the #4 cylinder while all the others were less than 2 percent. The problem was that my exhaust valve wasn't sealing for some reason.
Now that I've got my new heads and new valves installed I need to do it agian and see what I come up with. It makes 365 horsepower so I'd say it will be pretty good. :D
Old Sep 25, 2002 | 03:57 PM
Raistlin's Avatar
Raistlin
i'd say comparison between the tests will tell you nothing, but comparison of the cylinders of todays test shows #2 a little weak. did you test #2 again to make sure the results aren't skewed?
the next thing i'd do is a leakdown test, because #2 doesn't look too healthy. :(
Old Sep 25, 2002 | 04:20 PM
jfb's Avatar
jfb
Performing a hot test is dangerous to your spark plug threads if you have aluminum heads. I wouldn't do it.
Old Sep 25, 2002 | 05:14 PM
ncider's Avatar
ncider
I was thinkin' #2 seemed a little on the low side as well. I was thinkin' they all needed to be within 10 psi from each other.
Old Sep 25, 2002 | 05:21 PM
vettmech's Avatar
vettmech
Default Re: Compression test results Before and after (ncider)
The cylinders that went up or high were prob do to CARBON buildup..... sorry....... but yes do a leak test by all means........ :seeya
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
I have to agree with Nathan. After posting this morning on the increase, I thought I should have also mentioned the leakdown test.
I recently just found out my rings were leaking on my 350. They tested the drivers side only and found them all to be leaking at least 20%. One was as high as 50%! They did not bother doing the other side, no real point, the engine needed refreshed.
When I did my compression tests, on several different occasions, both hot and cold. ALL my cylinders were within +/- 2 PSI of one another! This would indicate a very tight engine or a very uniformly worn engine, which in my case is exactly what I had.
I also had a very small about of the ash deposits on my SP. That is a real good indication of OIL getting past the rings. I also had blowby that was seen around all the breathers in the vavle covers, and also when the oil fill was taken out when the engine was hot, you could see puffs of smoke coming out while the car idled.
I suspect a leakdown will yeild the answer you are not really looking for, but the right one. :confused:
LAter :cheers:
Old Sep 26, 2002 | 05:03 PM
SunCr's Avatar
SunCr
#2 certainly looks a little funky - bad valve(s) maybe? - I'd reject it hot and you can minimize the chances of stripping any plug threads by loosening the plugs when the engine is cold and just leaving them finger tight or a bit tighter while the motor warms up.
To Compression test results Before and after
