Iac
Old Mar 21, 2017 | 09:35 PM
0333griffin's Avatar
0333griffin
Cruising
Default Iac
I have a 1988 Corvette and I reset the IAC. It doesn't seem to want to start now. I do know the battery is low because I've been running the fan trying to clean it out with one of those stink remover machines.
It cranks, I hoping it's just a low battery. In not any other ideas?
Old Mar 21, 2017 | 11:23 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Welcome to the forum!
The IAC (or lack of a functioning one) wont really have an effect on your car starting or not. Now, once running, your IAC will control you idle speed during warm up.
If you know your battery low, you need to get that fixed. You engine will need to spin fast enough to catch.
Old Mar 22, 2017 | 01:59 AM
Cliff Harris's Avatar
Cliff Harris
Please explain how you did that.
The IAC will be reset if you connect ALDL pins A and B together. It continuously tries to close and you can hear it clicking when it runs out of adjustment (completely closed and bottomed out).
Old Mar 22, 2017 | 09:01 AM
0333griffin
Cruising
Thanks. I will give that a try.
Old Mar 22, 2017 | 03:11 PM
aklim's Avatar
aklim
If the battery is low, you may have issues starting so you need that fully up and ready before we go further. Why did you reset the IAC?
Old Mar 22, 2017 | 08:37 PM
0333griffin
Cruising
I did fully charge up the battery and it started right up.
The reason I reset it, I replaced it with a new one and forgot to set the same as the old one.
Do you have any ideas as to why I keep getting a code 32 and 33? I replaced the MAF with a new after market one last year. The code went away for a few months and then popped up again. I might have bought a cheap one.
Old Mar 22, 2017 | 08:47 PM
0333griffin
Cruising
I forgot to mention other than a small miss it runs fine.
Old Mar 22, 2017 | 09:32 PM
billschroeder5842
Fix the miss and it will run great!
Old Mar 22, 2017 | 10:47 PM
aklim's Avatar
aklim
You couldn't and shouldn't. It should be done by the ECM or indirectly. Pushing or pulling the pintle means buying a new one.
32 is EGR and 33 is MAF circuit. For your 33, could it be the relay maybe? I don't have an FMS for that.
Old Mar 23, 2017 | 02:37 AM
Cliff Harris
The IAC is recalibrated by the ECM every time you turn on the ignition. You don't need to do anything else. The FSM tells you to set the length of the IAC pintle because the plastic guide will break if the pintle is extended too far when the IAC is screwed in. The pintle bottoms out and then twists and breaks the plastic guide inside the IAC.
Error code 32 is EGR SYSTEM failure. If the EGR is not working you will get this error. It is usually caused by the EGR valve not opening and the EGR thermo switch not getting hot. A bad thermo switch or broken wire will also cause an error 32.
Error code 33 is MAF signal error. It happens when the MAF is not communicating with the ECM. That's usually caused by a poor connection (corroded) on one pin in a connector, but could be a broken wire.
Old Mar 23, 2017 | 08:25 AM
0333griffin
Cruising
I was reading up on that this morning. Maybe
Old Mar 23, 2017 | 08:29 AM
0333griffin
Cruising
I replaced the EGR value recently and the code stayed on. The old EGR value was definitely bad. I will look at the wiring and connectors again.
Old Mar 23, 2017 | 09:52 AM
aklim's Avatar
aklim
Just for the hell of it, did you clear the code? Pull fuse to ECM or something so you can scan it and have no history codes?
Old Mar 23, 2017 | 11:00 AM
0333griffin
Cruising
Just for the hell of it, did yo4u clear the code? Pull fuse to ECM or something so you can scan it and have no history codes?
I did yesterday and code came right back.
Old Mar 23, 2017 | 11:15 AM
aklim's Avatar
aklim
Anyone near you that can lend you their MAF for an hour or so? I'd really hate to buy another one
Old Mar 23, 2017 | 11:39 AM
0333griffin
Cruising
That's a great idea. I will check.
Old Mar 23, 2017 | 11:43 AM
aklim's Avatar
aklim
20 maybe 30 minutes should be fine
To Iac
Old Mar 24, 2017 | 05:25 PM
0333griffin
Cruising
Default Fixed
Will I got it fixed today. I cleaned the throttle body and found a small air leak.
The car sounds great!
Thanks everyone for your help!
Old Mar 24, 2017 | 09:46 PM
skidball's Avatar
skidball
Besides a few squeaks , rattles , and miss fires . It's a pretty good car. Lol. If I wasn't laughing, I'd be crying. 92 lt1.
Old Mar 28, 2017 | 11:20 AM
0333griffin
Cruising
They are fun to drive!
