Throttle cables question...
Old Mar 22, 2017 | 08:40 PM
racerseks's Avatar
racerseks
Default Throttle cables question...
Well I got my plenum back on today, but it's dark now so I came in. I goofed on one thing. Looks like I forgot to tuck one of the throttle linkage cables underneath the runner on the driver's side. Is there a way to get it underneath there without taking the runner or plenum off again?
Thanks!
Old Mar 22, 2017 | 09:54 PM
Tod Stiles's Avatar
Tod Stiles
Thanks!
I've done this to myself. I assume you're talking about the kick-down cable that goes under the plenum and runners. I had swung it up out of the way and forgot to put it back down in there. Anyway, I don't have a trick solution. I had the dist. cap off and moved the wires and vacuum lines out of the way and then very carefully fed the cable under and through. It was like defusing a bomb - one false move and. Well I don't need to tell you. The sun was on it for awhile so that may have helped. Maybe use a hair dryer on it to soften the plastic?
Old Mar 22, 2017 | 11:15 PM
racerseks's Avatar
racerseks
Yes, that's the one. I hear ya...everything I do to it is like that. 30 year old brittle plastic, that snaps every time you touch it. I'll have to look at it again...maybe I can take the runner off on that side, but hope I don't have to...again! Thanks!
Old Mar 23, 2017 | 01:17 AM
racerseks's Avatar
racerseks
If anyone has had this happen and has any ideas, please let me know. Otherwise, it looks like I'll be taking the runner off the driver's side tomorrow. Hate having to do that...just got it in right, and put a lot of other stuff back including that EGR tube...that'll probably have to come off to get that last torx in, and it's just kind of "fragile", for lack of a better word. Anyway, got my fingers crossed. Please chime in with any thoughts. Thanks...
Old Mar 24, 2017 | 12:09 PM
racerseks's Avatar
racerseks
Having coffee now (I keep late hours), and about to get started on this. Have a few more things to do before getting it started though. Any more thoughts on getting that kick down cable tucked under the runner without taking the runner off? Maybe I can just loosen it, but anxious to hear any last thoughts. I'm slow, but exhaustingly thorough with this stuff. Seems like it'll take an hour, but more than likely I'll be out there till dark. With the other stuff I have to do I'll probably be lucky to get to the start it up phase. You might save me hours with a quick tip, ha ha. Hey, I'll say this for myself, I'm not afraid to admit how long something takes me, and sure not afraid to ask for help!
T-40 in hand...
Thanks...
Old Mar 24, 2017 | 12:57 PM
Tod Stiles's Avatar
Tod Stiles
I've unbolted the plenum from both runners and the throttle body then pulled the plenum straight out/up. The risk there is tearing the gaskets. I think if it were me I'd loosen the passenger side runner (seems easier for me to get at the bolts and no cold start valve to deal with). Unbolt the plenum and move it to the passenger side. You only need a quarter inch or so to get the cable past it.
Seems like six of one half a dozen of the other to unbolt and remove the drivers side runner, but that's just me.
Old Mar 24, 2017 | 01:08 PM
s carter's Avatar
s carter
I have snaked it up as Mentioned Earlier, But the Risk of things Breaking is high given the age (I cracked a Cable Jacket and that was 25 years ago), Best bet as Mentioned Loosen a Plenum and slide the Middle out Things are fresh and Unstuck as long as you didn't use a gasket glue.
racerseks's Avatar
racerseks
Thanks for your thoughts...You got me thinking, and that might be the way to go. I'll try one of those. I was dreading that driver's side with the cold start injector and Torx on the inside. My EGR is fragile, and I got it in just right now.
Any more thoughts welcome, but that already has me feeling better about things...
Old Mar 24, 2017 | 01:23 PM
racerseks's Avatar
racerseks
Yea, you had me scared when you mentioned it was like "diffusing a bomb". After taking things off over and over again, I've had a few snaps here and there.
I'll do that. The less I have to take off the better. Nope, no gasket glue used. luckily.
Appreciate your thoughts...any and all welcomed!
Thanks!
Old Mar 24, 2017 | 10:17 PM
racerseks's Avatar
racerseks
Hey, this turned out to be pretty easy. Took about 15 minutes. Sorry I made a bigger deal out of it than it was. Thanks for all that shared their thoughts on it...
Old Mar 24, 2017 | 10:20 PM
Tod Stiles's Avatar
Tod Stiles
Good gravy man!
You must tell us how you decided to do it. Don't leave us hanging, we need closure!
Old Mar 24, 2017 | 10:30 PM
racerseks's Avatar
racerseks
Good gravy man!
Oh, ha ha...sure! Just wasn't sure anyone was listening, LoL...
Okay, well I took out all 8 plenum bolts, and only loosened the bottom passenger side runner bolts. From there lifted out the plenum with plenty of room. Took the kick down cable out of the bracket by pinching the plastic retainer gently with some pliers. From there the cable went right in, and I tightened it all up again...double checking the driver's side bolts as well.
Thanks for getting me to think about it the right way...and to anyone facing this dilemma in the future, it's not a big deal. If you have it all tightened up and ready to turn the key and get frustrated, just do it the next day instead.
To Throttle cables question...
