C beam Dana 44
Old Mar 29, 2017 | 09:46 AM
mrodoc's Avatar
mrodoc
Default C beam Dana 44
Sine I've done a Lloyd Elliot stage II build and a 3000 converter I've decided to get rid of my Dana 36 with 3.07 in my 1994 and go to a Dana 44. I have found a good deal on a torque arm drive shaft beam (c beam). It is from a ZF 6 sp. Will this work with a Dana44? Also, does anyone know of a good source for a driveshaft? Thanks Gary
Old Mar 29, 2017 | 10:42 AM
WVZR-1's Avatar
WVZR-1
Since the only C4's that actually had a D44 were all manual transmissions the C-beam needs to be from a manual of some sort. The ZF C-beam will be fine. The drive-shaft from the same car would do well also and you just change the slip-yoke to the mate to the A4.
Old Mar 29, 2017 | 11:09 AM
ghoastrider1's Avatar
ghoastrider1
I read somewere in here that you will need a 1/2inch shorter driveshaft. I do NOT know if that's true, just passing it along.
Old Mar 29, 2017 | 12:30 PM
mrodoc's Avatar
mrodoc
It will require a shorter driveshaft. I just didn't know if someone knew of a source. Thanks
Old Mar 29, 2017 | 12:53 PM
aklim's Avatar
aklim
The DS is different.
Old Mar 30, 2017 | 08:54 AM
C409's Avatar
C409
..... Find a driveshaft shop near you ... there are several here in the Tampa Bay area , there is bound to be one near you that can tell you how to measure for the new shaft , but FWIW I generally have a D36 shaft shortened by 1" for D44 apps and have never had a problem ... shorten , rebalance , and new u-joints installed is around $200 .....
Old Apr 11, 2017 | 09:52 AM
JoBy's Avatar
JoBy
I reused the dana 36 driveshaft and redrilled the c-beam.
http://joby.se/corvette/mods/2001-0X11_diff/
The driveshaft was not too long when in place, but too long to mount without unbolting the c-beam and dropping the rear of the tranny a bit.
Old Apr 11, 2017 | 11:10 AM
WVZR-1's Avatar
WVZR-1
Good to see you visit! It's been awhile!
I've used your C4 wheel ID information for many years. Contributed some information to you a couple times to get it to where it's at now. There's way more information regarding C4 wheels on your ID Specs than most others likely even know how to calculate. I've not checked accuracy recently but unless you've edited something or been "hacked" - it's easily the BEST
Those that aren't familiar here's what he contributed many years ago .......
http://www.joby.se/corvette/div/corvette_wheels/
Old Apr 11, 2017 | 04:37 PM
frankinvett84's Avatar
frankinvett84
I also just re drilled the C-beam and used my original drive shaft. works fine and Im running almost 500 HP. Not to hijack BUT does anyone know if I should use different shocks? I also re used my original they seem to be fine but I want to know what others have done. Thanks
Old Apr 11, 2017 | 06:56 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Nice to see you on here Jonas.
Old Apr 12, 2017 | 12:31 PM
mrodoc's Avatar
mrodoc
Thanks, so much. Invaluable information, and it will save me $$
To C beam Dana 44
