Any one know if the 94 will fit a 86 heard it is a little stronger and where would i find a specific 94.. please and thank you
Best I recall the pedal is '84 - '88, '89 - '91 and '92 through end of production. I've no idea if you could substitute BUT if you look on eBay for 10126447, 10066476 & 12551528 maybe you can visualize and make a decision for yourself.
There's a couple later "part outs" I believe in the PARTS SECTION now!! Ask for a deal!!
so nothing i can do for the 86 vette pedal? if so that is rediculous. these break all the time i have read on this forum everyone has used the 94 version since it is stronger.
My 84 throttle cable broke once well actually the plastic piece on it that holds it to the pedal (30 year old plastic go figure) but I never heard "these break all the time" is there something I should know about here?
The pedal has side by side m movement if u step on it not flush straight they will snap the plastic on The back.. spoke to ecklers looks like there looking into making a steel one cause this is such am issue
See my earlier post. There already is a metal mount available on the website I noted.
