Because your fuel becomes a vapor. When it does, the volume becomes less but because the vapor mixes with the air, it takes up the space left behind when the fuel becomes a vapor and then some. As such, pressure increases?
The fuel system in Corvettes recirculates the fuel. It is pumped up to the engine fuel rails and then any extra fuel travels back to the tank. While the fuel is going through the fuel rails it picks up heat from the engine.
What happens is that the fuel in the tank gets hotter and hotter as the car is driven until it stabilizes. When fuel gets hot it expands. That is what causes the pressure.
And if you drop a match into that tank, you'll know what causes the increase in pressure.
The vent pipe from the tank is in fact located in the brake pipe bundle running all the way to the front of the car under the drivers sill and it usually blocks and corrodes.
Here in the UK, we don't need that so I removed the entire evap system and fitted a 'roll over' safety valve at the tank which allows the pressured vapour (vapor) to escape yet block off if the car is upside down. The fuel cap is non vented.
a certain amount of pressure in the tank is normal. fuel vapors generated in the tank are vented to a charcoal canister, controlled by the ECM and a purge valve and is vented to the engine under certain conditions. if these conditions are not met, vapors will build, thus pressure. it's all part of the evaporative emission control system, and covered in the FSM. however, not only do I smell gas, I smell a , but then again, that's JMO -
now, not to feed the , I mean the OP, here's a fairly useful thread from a third-gen Camaro forum on the maintenance and repair of the EECS...
The evap pipe corrodes where it runs over the rear axle (same as the steel fuel pipes on the other side!) and also in the brake pipe bundle usually where the bundle is secured.
You could probably run a line of rubber fuel pipe from the tank to the charcoal can easier than replacing the steel pipe if your location states that you need this to be operational for the annual vehicles check.
I also noticed a surprising amount of pressure in my tank when opened, possibly due to not being opened in so long? none of my other vehicles have done this.
