Hi , i have a 94 C4 with LT1...this thing started to misfire like hell , i read that a MSD distributor could help but MSD is not what it used to be...should i stick with a OEM unit or go with a MSD distributor anyway? tkx
SKIP the MSD idea. OE only! problem is VERY scarse to find! 1st simple diagnostics eliminating other possibilities. Codes, Fuel pressure, pump voltage, control module, Coil, plugs, wires?
A typical Opti going bad runs ok cold. Warms up. Then major misfires. But do not be the parts changer! Confirm!
start to misfire when getting warmer...worst when engine is at operating temperature.
