IAC REMOVAL
Old Sep 25, 2002 | 09:59 PM
mjfox's Avatar
mjfox
Default IAC REMOVAL
I was thinking of cleaning my iac i have a rough idle .
Is it hard to remove
any help would be appreciated
thanks MJFox
Old Sep 25, 2002 | 11:05 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: IAC REMOVAL (mjfox)
It is not hard to remove the IAC. Just be sure you disconnect the battery before you do anything. Use Intake manaifold cleaner on it and clean your throttle body at the same time.
While you are at it, why not do the throttle body bypass of the coolant :cheers:
After reinstalling the IAC you should adjust the TPS. There is a specific procedure to do this properly located in tech tips.
Old Sep 26, 2002 | 01:34 PM
Ron78Z&66Vette's Avatar
Ron78Z&66Vette
Default Re: IAC REMOVAL (85vet)
I think the manual cautions against using any type of solvents on the IAC. I think it has to do with solvent getting into the inner workings. I'd just scrape the crud off the end and wipe off the residue with a rag.
.....but that's me :seeya
Old Sep 27, 2002 | 08:46 PM
lspalding's Avatar
lspalding
I couldn't get at the IAC with a wrench or a pliers. It's too tight down there and it's a huge nut. Took the throttle body off and cleaned up the whole thing. It was a piece of cake. You'll need a gasket set. Got at Auto Zone for $5. Have better performance all around, and a little higher, smoother idle.
Old Sep 28, 2002 | 01:15 AM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: IAC REMOVAL (Ron78Z&85Vette)
The manual recommends that you do not emerse the IAC in fluids!
Old Sep 28, 2002 | 11:19 AM
ittlfly's Avatar
ittlfly
Your bio says you have a 92. For that year there is no adjustment for the TPS as with earlier models. Don't use cleaning agents on the IAC. Just carefully clean it with rags and check the pintle deapth when reinstalling (1- 1/8" ). You can use throttle body cleaner to clean out it's location in the throttle body itself.
Good luck.
Old Sep 28, 2002 | 11:24 AM
Rick92's Avatar
Rick92
Default Re: IAC REMOVAL (lspalding)
I used an 1 1/4 thin wall deep socket probably a one use tool :cheers:
To IAC REMOVAL
