brake pad reccomendatios please
Old Sep 25, 2002 | 10:34 PM
rxbdwl's Avatar
rxbdwl
Default brake pad reccomendatios please
I don't race on or off the track. I just want decent pads that produce little dust and don't squeal. What's best?
Thanks in advance for any help.
Rex
Old Sep 25, 2002 | 11:15 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: brake pad reccomendatios please (rxbdwl)
I love my Hawks but they are a little dusty. Very quiet and stop great. You may also want to look at EBC green. The tirerack has them. Supposed to be quiet and low dust.
Old Sep 25, 2002 | 11:56 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: brake pad reccomendatios please (92TripleBlack)
Anybody know another source besides Tire Rack? I refuse to do business with them anymore(long story).
I have the NAPA Ceramix on my '95, no idea what's on my '93 which is why I'm ready to change them.
Old Sep 26, 2002 | 01:53 AM
SSLT1KID's Avatar
SSLT1KID
Default Re: brake pad reccomendatios please (Mr Mojo)
i run the Raybestos Brutestops on my cars. they are a carbon enhanced pad with a life time replacement warranty. (never buy pads again) the price is good and the performance is EXCELLENT!
[Modified by SSLT1KID, 5:54 AM 9/26/2002]
Old Sep 26, 2002 | 10:09 AM
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
Default Re: brake pad reccomendatios please (SSLT1KID)
I'm currently running EBC Greenstuff. I can't complain about performance...excellent braking and they have little or no fade apparently due to the Kevlar based materials. The claims of "dust free" or slight dusting however is exaggerated. I'd buy them again.
Old Sep 26, 2002 | 10:19 AM
vettmech's Avatar
vettmech
Default Re: brake pad reccomendatios please (Hardcorvette)
I use the NAPA pads and would buy them again and they have a lifetime warranty also :seeya
Old Sep 26, 2002 | 10:23 AM
92TripleBlack
Default Re: brake pad reccomendatios please (vettmech)
Hi Mojo, If you don't want low dust and want regular dust, I'd look at the hawks. I love mine. They dust a little more than stock, but then with the C5 upgrade the pads are also 40% larger so that's to be expected. I got those from ZIP through the forum mall for something like $75. I've seen the EBC elsewhere but I don't recall where unfortunatley.
Old Sep 26, 2002 | 11:33 AM
Mez's Avatar
Mez
From: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
I installed the NAPA ceramix at 30k miles. They should be broken in properly for best stopping. They produce very little dust and do not make any noise. A little touchy on initial pedal application but not objectionable. Very expensive unless you get a deal from a NAPA dealer. A forum member sold me the fronts at a substantial discount.
I did not turn my rotors. Simply sanded them with an orbital sander and 150 grit paper to remove most of the shallow grooves. That's what the Helm's manual says, surprisingly. It also said do not turn the rotors unless you have pedal pulsation.
Old Sep 26, 2002 | 11:42 AM
Nathan Plemons's Avatar
Nathan Plemons
I have the Performance Friction Z-rated pads. They stop great, but when they get really warm they begin to squeal a little bit. They also dust pretty heavy if you use them hard. They probably aren't exactly what you are looking for. Remember however that a dustless pad is a stopless pad.
Old Sep 26, 2002 | 02:00 PM
vader86's Avatar
vader86
Default Re: brake pad reccomendatios please (Nathan Plemons)
they dont make PF Zs for 85s :(
Old Sep 26, 2002 | 02:37 PM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
I wish I knew what was on my 96 now... no dust, stop good and no noise... they are getting close to needing replacement thou, so I think I'll be going C5 front setup with the Napa Ceramix all the way around.
Old Sep 26, 2002 | 06:56 PM
vette92_1's Avatar
vette92_1
Default Re: brake pad reccomendatios please (Springer's LT4)
Same here on my 92. I can't remember what brand, because I bought "Pre-Loaded Calipers" for the front from Auto Zone. When I bought them I figured I would be changing the pads out soon after, but suprisingly, they stop good, little dust, and zero noise. I will look to see if I still have the original box that the calipers came in, but I figured the pads were just house brand, which usually suck.
Update: I just found out what my pads are. They are "Performance Friction." I never have heard of them before, but I have to say I am impressed.
[Modified by vette92_1, 5:05 PM 9/26/2002]
Old Sep 26, 2002 | 07:04 PM
ZylaRace's Avatar
ZylaRace
Default Re: brake pad reccomendatios please (vette92_1)
I'm not sure if EBC makes pads for an 85, but I really like mine, (green). They cost less than Hawk. I have seen no dust from mine. This version is NOT a track pad. I tried to bed them like a track pad, they didn't like that too well. I have found them to be very predictable.
As far as where to get rather than TRack, try an Email: sales@ebcbrakesusa.com
I took a couple days to hear back from them, but they were helpfull.
Old Sep 26, 2002 | 07:08 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I have Raybestos Plus pads front and rear; good stopping, quiet and little dust.
To assure quietness, don't foreget to bed the new pads and put some anti-rattle on the pad's metal backing. Also, replace the spring clips that supply tension between the front pads and the caliper.
Old Sep 26, 2002 | 10:19 PM
rxbdwl's Avatar
rxbdwl
Default Re: brake pad reccomendatios please (65Z01)
Thanks to all for the replies. Now I just need a free week end to put them on.
FSTRNU's Avatar
FSTRNU
I have Performance Friction Z-Rated also. I havent had a wreck yet so I guess they work good enough. :yesnod:
Old Sep 27, 2002 | 12:39 AM
Jay Axson's Avatar
Jay Axson
I am using NAPA Ceramix they meet your goals, no squeel, very reduced dust. I have them on the front. It's really strange to see the rear wheels getting dirty much faster than the front.
Old Sep 27, 2002 | 07:34 PM
tkrussell's Avatar
tkrussell
I've been pleased with the PFC Z-Rated pads. I wash the car once a week, and the dust is not a bother. If they don't make them for 85's, that's a shame, but the Hawk's seem to be a good alternative.
To brake pad reccomendatios please
