vibration question - source and concern???
Old Apr 1, 2017 | 07:25 PM
keithhogan's Avatar
keithhogan
Default vibration question - source and concern???
my '95 LT1 vibrates pretty badly in the rear when I shift down from overdrive to drive at about 55 - 60mph. I could use some help with what my be going on, and what to check.
thanks for any feedback.
Old Apr 1, 2017 | 08:25 PM
jsinga's Avatar
jsinga
I
1st thing I'd check is half shafts ujoints
Old Apr 1, 2017 | 08:30 PM
hcbph's Avatar
hcbph
Originally Posted by jsinga
I
though I'd expect you'd hear something accelerating . I'd also check your bushings along with the u-joints on the drive shaft also. Then the wheel bearings.
Old Apr 1, 2017 | 08:32 PM
keithhogan's Avatar
keithhogan
thanks - I appreciate the input.
Can I get a visual on these without putting on a lift? what am I checking for?
Old Apr 1, 2017 | 08:33 PM
keithhogan's Avatar
keithhogan
actually I do feel a vibration at times when accelerating. maybe you are on to something.
Old Apr 1, 2017 | 11:50 PM
keithhogan's Avatar
keithhogan
if I need to replace a half shaft or drive shaft ujoint should I replace all of them? I have 58K on the odometer.
Also I just found out today that this car (new to me) has not had a lube since 2012 even though only driven 1000 miles.
Can this be a grease job fix?
Old Apr 2, 2017 | 10:15 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
How is your wheel balance? I've seen a wheel throw a weight and it feels like the back of the car is shaking itself apart.
You will especially note a weight issues during the "transition point" from acceleration to deceleration.
Aside from the balance, I'd check the U joints too....
Old Apr 2, 2017 | 07:32 PM
keithhogan's Avatar
keithhogan
Each wheel has weights attached but having them balanced is probably a good place to start. Then look into the U joints.
thanks for the idea
Old Apr 3, 2017 | 07:10 PM
keithhogan's Avatar
keithhogan
checked with two shops today to get an estimate on replacing all six u-joints. They both estimated a whopping 10 hours labor. Basically a $1000 deals. This seems very high.
I will still go the balancing and lube route first, and see what difference it makes.
Old Apr 3, 2017 | 07:31 PM
billschroeder5842
YIKES! This is a 4 hour job max.
How handy are you?
Old Apr 3, 2017 | 07:46 PM
keithhogan's Avatar
keithhogan
I have no jacks / lift, and only have average tools. I trust that you are correct and I will be contacting other mechanics. Thanks for the input. 4 hours I can live with.
Old Apr 3, 2017 | 08:03 PM
jetskibruce's Avatar
jetskibruce
I just did an alignment on mine and it really smoothed out. I think it can cause vibration tht feels like an unbalanced tire.
To vibration question - source and concern???
