No Power (new battery)
First I would eyeball every electrical connection under the hood an make sure nothing seems foo.
Then I would probably pull all fuses with the battery out, then connect a volt meter between negative battery post and negative battery lead. Use a meter that can support 10A at minimum (majority do) and set it to read amps in the mA range (ie 20mA).
On my 96 it will pull 30mA (.03A) of power when parked, key out, doors closed, interior lights off, older vettes are less. Then start putting each fuse in and see if there is any dramatic change on amps being pulled. If there is a dramatic change give it a second as it could be just a circuit needing to re-energize. If it doesn't settle down then you've at least narrowed it down to the circuit that might be causing the problem.
A lot of sparks would seem to indicated something is drawing high power or is shorted out.
Don't try starting the car though it will blow the fuse in the multimeter.
if the car was cranking and suddenly stopped and now what sounds like a short circuit that isn't fused
with battery disconnected disconnect the positive cable at the starter and make sure it isn't touching anything
then see what happens when you connect the battery
I'm not having this kind of problem yet but want to learn how to diagnose if I do. The paragraph above has me a little confused.
1. Before pulling fuses does the battery need to be removed or just remove the negative cable? Negative able off.....then pull fuses.
2. Then next, connect the voltmeter between the negative battery cable and the battery negative post with the positive cable still on the battery. This completes the circuits with the exception of the fuses being removed. Correct??
3. Now the technical stuff....30ma on a shut down '96. That information is going into my maintenance notes for future reference if needed to diagnose issues in my LT4 some day.
I might be wrong but seems logical to me.
I had a problem where my Selective Ride Control module shorted out and was drawing 1.2A when off...every morning I'd come out and car would be dead. So I did the above steps and pulled each fuse until I saw the current suddenly drop from 1.2A to 30mA...voila found the circuit I needed to investigate further which, as I mention, turned out toe be the SR control module.
The reason I suggest to the OP to pull all fuse is because he mention he was seeing a lot of sparks which tells me he has a much more serious current drain...one that can cause a fire if not careful. So I think he's better off pulling all fuses and going from there instead of 1 at a time like I did with my problem.
Current draw above what is normal can be scary in a car, because it means something is pulling current which generates heat and this can lead to a fire.
IT is a 1988 C4 Corvette.....I figured out the problem....the starter was shorted to ground....took the pos lead off the starter, hooked the battery back up, no sparks and the lights all came on....bought a new starter and it cranked right up....thanks for all the input and one of yall nailed the problem right on the head even with out all the information needed....
