87 Fuel Pump Relay Connector
Old Apr 10, 2017 | 04:37 PM
Tom454's Avatar
Tom454
Default 87 Fuel Pump Relay Connector
How do I release the pins from the male connector that plugs into the fuel pump relay? They have to release somehow. I need to perform CPR (Connector Plug Resuscitation) on it due to bare wires. Seems to be a common problem with this design.
Old Apr 10, 2017 | 05:05 PM
WVZR-1's Avatar
WVZR-1
If the style of the relay hasn't been changed from OEM then it's a Pack-Con Female like in this link. I used this image because you should be able to ZOOM etc. The tab should be obvious!!
https://www.waytekwire.com/item/3103...ose-Terminal-/
Old Apr 10, 2017 | 05:08 PM
Tom454's Avatar
Tom454
Thanks... got it apart.
To 87 Fuel Pump Relay Connector
