Does anyone know which one it is? And can i reach it without removing the digital dash?
/Svante.
I would think so. Do you have the FSM for the car? I'll sort my FSM for the various connector ID's and wire pinning and post back.
Use the link from my "USER ID" and drop me an email so I can send them directly to you. Just click on WVZR-1 and the email link should be available. You can have it this AM - likely in 60 minutes!
Yes it shouldn't be a problem. There's a 15 pin connector (C209) near the fuse block. There should be a PINK wire at pin E I believe. That would be I'd think the least non-destructive point to gain access.
Great,
No i have no issues, i need to find the wire to connect my autometer fuel level gauge. Didn´t want to run a new wire from the fueltank when there is one already
Great,
I think i can manage to find it now.. Thanks!!
If your gauge will work with a 0Ω = EMPTY and 90Ω = FULL you could be all set. Do you use the original fuel tree for pump(s)?
Great,
