4+3 modification ?
Old Apr 13, 2017 | 04:39 PM
Zackery Pollard's Avatar
Zackery Pollard
3rd Gear
Default 4+3 modification ?
Hi, would anyone have any knowledge to share about modification of the shift linkages or pivot brackets? I would like to shorten my shift throw up a bit before dropping my engine in.
Old Apr 13, 2017 | 04:45 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
i would LOVE to do the same before i put mine back together. subbed.
Old Apr 14, 2017 | 08:59 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
There used to be short throw kits. They consisted of the levers that attach to the transmission shift forks. They shortened the length of the levers to make a shorter throw on the shifter.
However, I have not seen these for a long time. If you are lucky, you may be able to find some. Possibly they are the same as some of the other four speed shifters that come with these levers. You might call some of the shifter companies and see if they will interchange.
Good luck.
To 4+3 modification ?
