96 cranks but no start
Old Apr 13, 2017 | 06:26 PM
bob arrowsmith's Avatar
bob arrowsmith
Default 96 cranks but no start
my 96 just cranks, strong raw gas coming from exhaust, removed all plugs they were all wet with gas and fairly sooty or black,,,injectors are pulsing and have fire to the plugs,,its flooding very badly could i have a bad fpr causing all cylinder s to have raw gas in them...? and is that the only reason all cylinder would flood,,,thanks for any help...and yes i will be changing the oil, there is also strong smell there,,,while the plugs are out i will also do a compression test .
Old Apr 13, 2017 | 07:05 PM
THE 383 admiral's Avatar
THE 383 admiral
Bob, sorry to hear this! The fuel smell highly suggests the FPR has a torn diaphragm. any fuel smell in a vacuum hose? do you have a fuel pressure gauge to confirm pressure @ the rails. any codes? you could have a bad CTS, CPS or related sensors.
Old Apr 13, 2017 | 07:48 PM
bob arrowsmith
thanks for the reply,,, i have about 40 lbs with fuel gauge hooked up, and no codes registered on code reader.; earlier there was a slight smell in the vacuum line, after i do a compression test i am going to replace plugs, this is a 383 , hot cam, rr s,,,the existing plugs are platnium, what would you suggest i use for new plugs.
Old Apr 14, 2017 | 11:03 PM
THE 383 admiral
Only, one type of plug in my book. NGK r plugs. aka V-groove.
Old Apr 18, 2017 | 04:48 PM
bob arrowsmith
Default 96 cranks , will not start
update ,,, still will not start, i have spark to plugs , spark from coil, injectors are pulsing, remove injectors and placed ontop of intake to view, no leakage, installed new batterys, checked fuses on passanger side, they all look good, im stumped...
Old Apr 19, 2017 | 10:03 PM
1800Wing's Avatar
1800Wing
Flatulent Dwarf
Damn...this has to be making you nuts, You've got spark...you've got gas..Is the spark good and hot blue ? or yellowish ? Anti-theft shutting it down maybe ....?
later, tiny
Old Apr 19, 2017 | 10:55 PM
Bagpype's Avatar
Bagpype
Check your timing. (Is that possible with the Opti?)
Old Apr 24, 2017 | 04:40 PM
bob arrowsmith
i have not been able to get back at trouble shooting but nothing has changed, installed new plugs, still cranks and i can smell gas,,i read somewhere that the tach is supposed to show a few rpms when cranking but it just sits there and does not move, where does that signal for the tach come from. pcm or opti,,, this is a new opti from petri, and has been working great for about 2 months,, 2k miles about, so i am getting a service manual to trouble shoot , hope to eliminate the opti or not, if it is i will have to remove it and send it back...im hoping it is a bad connection, when i can get back at it,,is there a down and dirty way by just making some quick probes with a meter to varify if it is the opti or something else,, thanks
Old Apr 24, 2017 | 08:00 PM
1800Wing's Avatar
1800Wing
Flatulent Dwarf
Bob,
I have the FSM for the 96, looking through the troubleshooting guide for "Engine cranks but does not run" ( page 6-305 ) one of the first things it mentions is a stuck EGR valve causing a low air/fuel mixture.
later, tiny
To 96 cranks but no start
